Wheel Cylinders
Discussion in '1947-1954' started by JW 54, Jun 1, 2010.
  1. JW 54
    JW 54 Member
    Cypress Texas
    The front right wheel cylinder on my truck is starting to leak, so I figured I would replace all four. There seems to be a wide range in pricing from local auto part stores. I'm sure quality is different also. What do you guys reccomend?
    Thanks, JW
  2. Kens 50 PU
    Jerry, I've always found NAPA to have more parts for our trucks than any other FLAPS in town. When comparing prices between NAPA, O'Reily's, and AutoZone in our neck of the woods, check to see who carries the best warranty on the parts too.
    Ken
    Pricing
    Now you see how badly you usualy get screwed on Auto parts...
    Unless you're brand consious , just buy the cheapest ones .
    Be _sure_ to thoroughly flush the entire system using only brake fluid , alcohol or Aerosol brake cleaner , NOTHING ELSE .
  4. Wolf
    Wolf Member
    Kansas
    you can always check out our host, and lmc truck, and Jim Carters.
    I would try napa, and O'rielly's I have had good luck with them as well.
  5. JW 54
    JW 54 Member
    Cypress Texas
    Thanks fellas I think I will go with NAPA. They have them in stock.
    JW
