wheels
Discussion in '1973-1987' started by 76454, Jun 12, 2003.
  1. 76454
    76454 Member
    seattle
    [updated:LAST EDITED ON Jun-12-03 AT 01:51 PM (CST)]So, I'm thinking about putting some new wheels on my rig. It's a 2wd at the stock height, and I want to put 18's on it. I'm just not sure about the width. Anybody know how wide I can go before I need to start trimming stuff?
  2. MPD_Chevy80
    MPD_Chevy80 Member
    Nashville USA
    There are alot of factors to consider when you go away from stock wheels. You can probably expect to go to about 275mm (P275/60R18) without the fender flares or affecting the suspension. If you want a tire that is wider then you need to start considering your options on the wheels you are choosing. A very important factor is wheel offset. Refer to these links to determine how far you need to go away or towards your truck's suspension.
    http://toy4two.home.mindspring.com/offset.html
    http://www.usacomp.com/Offset.htm
    http://www.1010tires.com/wheeltech.asp
