which mark is the right one on flywheel for top dead center
Discussion in '1947-1954' started by wokri, May 1, 2010.
  1. wokri
    wokri Member
    Germany
    Hello,
    I ask for the mark on the flywheel for adjusting the ignition and now I have another question, which is the mark for the adjustment on the flywheel for adjusting the valves? The steel bal also?
    I adjusted the valves when they both open when the pointer at the flywheel house is showing to the triangle. Did I made a mistake?:mad:
    Wolfgang
  2. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    when you adjust the valves, adjust the intake with the exhaust all the way open and adjust the exhaust with the intake all the way open. Then go to the next cylinder and start all over until you get to the end....Big Tim :cool:
  3. wokri
    wokri Member
    Germany
    Thanks
    Hello big Jim, thanks! So I understood you right, that the top dead center has nothing to do with the steel ball on the flywheel, this one is only for adjusting for the ignition.
    Wolfgang
  4. bigtimjamestown
    Jamestown Ca.
    That's right, You don't need to use the timing mark to adjust the valves....Big Tim :D
  5. Chiro
    Chiro Member
    If you follow the most excellent valve adjustment procedure posted on Deve's website by our own Nathan Hall, you will see that TDC is indeed important when adjusting the valves properly. Follow the instructions in the link below to the letter and you will have the very best adjusted valves for your engine.
    However, I did ask Nate the question about the ball in the flywheel vs. the triangles or "Chevrons". The triangles or "Chevrons" are actually the TDC mark and it is that mark which should be used when following the procedure in the link. The steel ball in the flywheel is purely for ignition timing.
    Here's the link http://www.speedprint.com/deves50/valveadjust.php
    Andy
  6. wokri
    wokri Member
    Germany
    Thanks Andy
    Hello Andy thanks. I thought also.:D
    Wolfgang
  7. vwnate1
    Thanx Andy !
    For posting that .
