will 81 - 87 front end fit on 78 gm
Discussion in '1973-1987' started by novatoasv, Jan 20, 2005.
  1. novatoasv
    novatoasv Member
    pulaski usa
    i'm interested in converting front sheetmetal from 81 thru 87
    on my 78 truck. would use the whole clip. will all mounting points work?? newer fenders, fenderwells, core support to older frame
    mounting points. also all wiring connections. any help, please.
    thanks in advance. novatoasv
    78truck,89truck,62comet
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    RE: will 81 - 87 front end fit on 7
    All the mounting points will work for the fenders and core support. The one problem is that you need to cut the cab a little bit to fit the rear hood hinges and cowl. I think the wiring harness will be the same if you go with single headlights, otherwise you'll need one for dual headlights.
  3. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    The holes you need to cut for the hood hinges are going to be 1.5" x 4.5" and should be 31.5" from the center, about 1.5" back from the front of the firewall.
