Will a newer ignition work?
Discussion in '1960-1966' started by mattcgtrguy, Dec 17, 2009.
  1. mattcgtrguy
    mattcgtrguy Member
    Tx
    I have a 1961 Apache and the cylinder is stuck in the ignition. Being new to working on old cars, I tried to drill out the key area to get it to release and now know that doesn't help! So trying to take the easy way out. Does the 1964 ignition sold at classic parts work on a 61 or does anyone have a suggestion on where I can find one that does work?
    Thanks for you help!
    Matt
  2. drabo
    drabo Member
    Patrick AFB, Florida
    Did you push the pin in with a paper clip and then turn the key to the left? Also you can get the ignition switch at a local parts store and compare with the old one. If I was to guess it should work.
  3. iretired
    iretired Member
    USA
    ignition switches
    Hi
    Since you have drilled out the lock cylinder it is doubtful you will be able to remove the damaged lock cylinder from the ignition switch. You will most likely have to replace the ignition switch with one that has a lock cylinder in it and comes with keys. The trick to removing an old GM ignition switch is to put the key in the lock, using a straightened paper clip through the little hole to the top right of the key depress the brass spring and rotate the key counter clock wise until you can remove the key and the lock cylinder. Then you can remove the bezel and the switch can be removed.
    Differences between most old GM ignition switches is the older ones did not have a starter position (used foot operated pedal "Chevy" or gas pedal operated "Buick" solenoid operator) and some did or did not have an unlock position where the key could be removed but you could still operate the switch and some had an accessory position to the counter clock wise position of lock.
    If your harness has a plug in harness to the ignition switch then the new switch has to have the same configuration as the old one. Old chevy trucks are pretty universal as to what fits what in the electrical department.
    Hope this helps.
  4. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    you can get them both very cheap at your local parts house, the time you spend trying to mess with it will be more valuable then the cost of new parts.
  5. mattcgtrguy
    mattcgtrguy Member
    Tx
    Thanks
    Hey guys,
    thanks for your help. I opted to go with a new ignition and cylinder. I'm sure I'll have more questions later.
    the newby.
