window channel
Discussion in '1947-1954' started by 51oleblue, Jul 24, 2012.
  1. 51oleblue
    51oleblue Member
    hey guys-
    i am having problems fitting the window run channel in the 51. i bought it from our sponser and can't get it to bend around the curve neatly. it bunches up bad, not sure if i need to cut it or not. any sugestions?
    thanks
    Joe
  2. ol' chebby
    Start at the front (vent window) DON"T glue this part yet...you will need to move it to insert the vent window. put the rest of the channel into the door. When you come to the curve push into the channel...DON"T pull and stretch it. I use the glass (if it is in the truck) or a small piece of plywood the same width of the glass to help press in and keep shape. You will always have to do a little hand messaging to get all the puckers out. Now glue the rest down the verticle run nd roll up the window and let sit.
    I think I have a post about this, also in the Ad assembly thread.
  3. 51oleblue
    51oleblue Member
    Thanks I will,give it a shot
    Joe
  4. Kens 50 PU
    Joe, check out the thread "free tool" by Coilover that Larry's 48 just revived. That shows it all.
