OK Experts, just starting re-doing the window lacing in my 62 C10. No problems with the sides, pretty easy stuff, but I'm having a hard time with the 2 pieces that clip in on the bottom portion of the window frame. Is there any simple way to install these, the darn window is in the way, I can get one in but not both. Please help! Thanks, Mike
[updated:LAST EDITED ON Jul-09-03 AT 06:58 PM (CST)]Hi Mike, Try this. Install one side first. Be sure to use a small bead of 3M weather strip adhesive on the back, let it tack-up, then push into place. Use a set of hand clamps to hold the fuzzie in place until dry. Once one side dries, use the clamps to hold the window tight against the side you just finished. Then install the other fuzzie in the manner above with a bead of adhesive. That should get it. Dennis
