Wiper motor issues
Discussion in '1947-1954' started by mobileortho, Aug 30, 2014.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I bought the electric wiper motor from our host some years back but it's never functioned as I think it should. The main issue is slack in the output shaft that prevents a full sweep or fully return to the park position. Is there any way to adjust to take out the slop? There's a set screw on top but I've played with it a bit without success.
  2. gary1of2
    gary1of2 Member
    Valley Springs, CA
    Mine does the same thing. I slide it left and right and I would get the into park but the the don't go all the other direction. I reach out and set the into park by hand. It sucks.
  3. mobileortho
    mobileortho Member
    Hampton, VA
    Someone suggested the Raingear system but $400??:eek: I see a few guys opting to use the S10 Blazer rear unit. The only draw back is it's a single speed unit.
  4. mobileortho
    mobileortho Member
    Hampton, VA
    Well, I found a rear Blazer unit for $20, mounted it to the Newport bracket, problem solved.
  5. Bill Hanlon
    My Newport unit works great.
