wipers
Discussion in '1960-1966' started by i love my 64, Mar 16, 2008.
  1. i love my 64
    i love my 64 Member
    Calgary,Alberta,Canada
    i have a 1964 GMC 910 and i can get the wipers to work any coments
  2. Hotrodkilroy
    Hotrodkilroy Member
    Wilton,Maine
    I say start simple then go complex. The problem is that to troubleshoot the wiper system u have to remove the cowl cover. then you gain access to the lingage. Make sure all the linkages move and while your there a little WD-40 gos a long way to keep things moving. if the linkages look good theres a nut on the end of the wiper motor take that loose and see if the motor runs without being conected to linkages. If not then your issue you have a bad wiper motor or wiring.and I asume u have checked the fuse allready. so trace wires for bare spots or shorts. u can pull the wiper motor and check it but it easier to just change it out especially if it orginal equipment. I hope this helps or at least gives you a direction to start. Kilroy Was Here
  3. drabo
    drabo Member
    Patrick AFB, Florida
    Using a simple voltage tester see if you have voltage going into the switch. After that check the motor. Most of the time it is the motor or a blown fuse.
  4. i love my 64
    i love my 64 Member
    thank guy it was just a fuse
