Wire Guage
Discussion in '1947-1954' started by LTurpin, Jul 28, 2012.
  1. LTurpin
    LTurpin Member
    St. Marys, OH
    What is the proper guage of wire I should use from my battery to starter using a 6 volt system? I'm not sure on the guage of wire I'm currently using, but it gets hot to the touch if I have to crank for a little bit.
  2. tims37
    tims37 Member
    OO Or the heaviest you can find. Do you have a tractor supply near by? They would have some heavy cables for use on old 6 volt tractors.
  3. LTurpin
    LTurpin Member
    St. Marys, OH
    I have a TSC about 2 mi. from my house, I'll go see what they have.
  4. LTurpin
    LTurpin Member
    St. Marys, OH
    The current wire from my battery to the starter is 4 ga.
  5. vwnate1
    Battery Cables
    Originally it was 1 gauge , going to 0 or 00 is good , this includes ALL oldies , 12 volt rigs too .
    Remember : it's critical to connect the negative battery cable directly to the engine block or the tranny , not to the frame then a jumper to the driveline .
    You'll have to get the pimple crusher behind the counter to open the catalog up and READ then order you up the proper length you need .
    I usually buy 0 gauge welding cable and solder on my own ends , this makes it not only crank super fast but the battery charges faster too .
  6. Kens 50 PU
    You'll need a cable length of 40".
  7. Bill Hanlon
    Morris Ranch TX
    Don't forget that the ground cable needs to just as large as the battery to starter cable. Best to attach it directly to one of the starter motor bolts.
