Hope someone can help, Installed a new reproduction harness from Classic Parts. There are no directions provided to give you an HEI distributor option. I have a reproduction of an original ignition switch and need to know if anyone out there has used this combination before. I don't want to slopily rig wiring. Want it to look good and work at the same time. Got to get Ol' Blue running again. Any help would be great. Doc
http://www.oldengine.org/unfaq/hei.htm Here is a link that will be of some help. I prefer hooking up to the PINK ignition switch wire. I use a crimp-on wire splicer, found at any hardware store. I like this hookup because it dosn't tie up one of the fuse panel outputs and using a crimp on splicer does not require that you strip any wires. DVal
