Wiring harness
Discussion in '1947-1954' started by Al Downs, Mar 24, 2022.
  1. Al Downs
    Al Downs Member
    What side of the truck does the wiring harness go from front to back?
    Driver's side, I *think* ~
  3. Al Downs
    Al Downs Member
    Thanks. I think once I get into it it will be self explanatory. Nothing said about it in the harness instructions.
    You're welcome .
    There's a nice assembly manual you can buy for $30 or so, it shows the *exact* location of every part, wire, nut and screw .
    Remember : buy a new rubber grommet where the harness goes through the firewall ! the only time you can install it is when the harness is out .
    *VERY* important .
  5. Al Downs
    Al Downs Member
    I will take a look. Thanks
    vwnate1 likes this.
  6. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Starter harness exits at the left of the VR and runs across the firewall and down to the starter. Main harness exits the fuse box and down the firewall and rearward down the frame on the drives side as Nate said. The assembly manual even shows the location of the clips.
    vwnate1 likes this.
