I have an 87 chevy crew cab and started it up the other night ...running fine...turned on the headlights and nothing happended. shut them off then the truck stalled...cannot get it to run now. starter turns over but nothing happens...thinking it might be a bad headlight switch and possibly a blown fusible link? any suggestions?
Could be bad headlight switch or maybe a bad ground wires for the lights. Can you check the battry to see if the battery is got 12 volts. Is fuse good in the box for the lights. Check all the basic wireing grounds & + . Try to see if the battery is takeing a big load when you try the light switch get some help have fire extinguisher just in case do as quick as posable. That all I can thing of right now maybe some one can give some more info . Good luck let us know if you find the the problem.
