hey Guys- does anybody have a good wiring diagram for the ignition switch / starter/ push button? I am running a chevy sb , using the original style key switch and a aftermarket push button ( simple it is the 40 amp spare from the door poppers) the button is pretty easy, the rest is a bit confusing. thanks Joe
Switch on sends 12v to button and 12v to coil. Button out to starter relay. When button is pushed, starter does it's thing until button is released. Switch accessory only goes to things like stereo.
Not sure this is what you are looking for but this might help? Here is one that I have for 12V: I can send you an email with the BMP since it is only allowing me to put in a small pic and I am sure it is hard to see everything. With the BMP you can make it as big or small as you need to to see all the wiring.
