Wood bed dimensions
parkbro
Jul 9, 2010
29
Location
North Carolina
Good morning folks....I've researched the wood bed layout for my 1966 C10 Fleetside and have my Red Oak planed, jointed and ready to rip to width and groove(rabet). I have measured twice to cut once.....but I have a question concerning the groove......I find a 5/8" rabet versus a 3/4" rabet a much cleaner/finished/tighter edge, but at the same time the 3/4" rabet is specified in all my research. I am concerned about expansion and contraction from season to season and was wondering if anyone had any experience with a bed not having enough clearance to expand?
Red oak can move as much as 1/8 " Especially when exposed to the elments , Be sure to seal all 4 sides of each board it will help.Have you ever seen a bed where the boards have bowed up and made an ugly hump . Kilroy was here!!!
Thank you Kilroy, I will seal all (4) sides and also all the holes to make sure it is sealed as completely as possible. I cut my boards to width last evening and plan to groove them this evening....I thought I'd start with my 5/8" offset and prefit all the boards and examine my gaps. If it appears they're too tight I will remove a bit more. Thank you for your response.
Measure twice cut once
I wanted to share my progress with the Red Oak I picked up locally from my Sawyer. I have it cut, bored to dimension and have applied my second coat of stain. I hope to have Sealed and finished by weeks end and hopefully post some photos
Bed Complete
Hi folks I wanted to share the end results of the wood bed installation. I stained the Red Oak with one heavy coat of Minwax Golden Pecan and 3 coats of Spar Urethane Satin with a 400 grit sanding between coats.
