WTB 6 lug rear end
Discussion in 'Truck Parts Wanted' started by cdk, Feb 6, 2011.
  1. cdk
    cdk Member
    Grandview,Tx
    with 3:73 or lower to 4:10 gears and no wider tham 60-61" wheel mounting surface to wheel mounting surface.
    Chris
    817 -517-3531
  2. Guest5979
    Guest5979 Guest
    rear axle
    you can put in a late 60s early 70s k 5 blazer with 6 lug not sure what year your truck is mine is a 52 1/2 ton and was able to use my backing plates so brake and e brake set up stayed the same.
    hope this helps
    Robert
  3. cdk
    cdk Member
    Grandview,Tx
    Thanks Robert ...that is what I need.
