Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 11-10-2009, 11:04 AM   #1
machinehead4820
Registered User
Cool 6 lug wheels
Does anybody know if you can use the late model 6 lug wheels on the early model 6 lug trucks? Pretty sure the lug size is different but heard the pattern is the same. Is there a special lug nut that can be used or would you have to drill the holes out bigger for the late model lugs?
machinehead4820 is offline   Reply With Quote
Old 11-10-2009, 02:19 PM   #2
markeb01
Registered User
markeb01's Avatar
About 20 years ago I used late model 15x6" & 15x8" disc brake wheels on my 1960 GMC and they fit and worked fine. I believe the stock early lug studs were 7/16 and the later design is 1/2", but the taper in the lug nut area is sufficient for the wheels to bolt up nice and tight.
markeb01 is offline   Reply With Quote
Old 11-10-2009, 08:46 PM   #3
dvalentine
Charter Member
dvalentine's Avatar
Cool
Quote:
In a word ? NO. They will not fit on the front due to the grease cup on the 60's truck. The later model wheels are "hub centric" and are intended for the late model axle that is smaller than the earlier versions.
dv
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 11-15-2009, 06:22 PM   #4
dado
Registered User
dado's Avatar
80 Factory rally wheels
Will 6 lug 80s factory rally rims fit a 62 ?
dado is offline   Reply With Quote
Old 11-16-2009, 07:38 AM   #5
62 short step
Registered User
62 short step's Avatar
Quote:
Yes they will.
__________________
www.louisianatruckclub.com
62 short step is offline   Reply With Quote
Old 11-20-2009, 09:04 PM   #6
LEYLAND
Registered User
LEYLAND's Avatar
DVal is right, the centres could be enlarged if desired but the backspacing is incorrect and doesn't look right, better and safer to get oldschool 4x4, aftermarket or check out other sources like Toyota...
__________________
LEYLAND
65 C10, 350, 700R4
LEYLAND is offline   Reply With Quote
Old 11-22-2009, 08:55 AM   #7
gulffishin
Registered User
gulffishin's Avatar
Sorry to bust in on someone else's thread , but Toyota huh?... I didn't know they would fit. I have a 93 Toyota 4x4 too, and have some old rims at my disposal I'll have to see if they fit one day.
gulffishin is offline   Reply With Quote
Old 11-22-2009, 08:11 PM   #8
jaybyrd66
Registered User
jaybyrd66's Avatar
yes a toyota 6 lug rim will fit a 6 lug chevy and i found out that a 6 lug dodge rim will also fit the 6 lug chevy pattern. or atleast thats what ive heard. never tried it myself
jaybyrd66 is offline   Reply With Quote
Old 11-23-2009, 09:21 PM   #9
dvalentine
Charter Member
dvalentine's Avatar
Cool
Quote:
The Dodge will swap with Ford six lugs, but not any GM six lug.
dv
__________________
Old 11-25-2009, 07:01 PM   #10
jaybyrd66
Registered User
jaybyrd66's Avatar
Quote:
dv
yea i proved myself wrong too lol. its the dodge 8 lug that will swap with a chevy 8 lug. oops. my friends boss bought a set off of a dodge and put on his duramax. i was thinking about the wrong lug pattern, sorry
Old 01-14-2010, 01:57 AM   #11
willz66
Registered User
willz66's Avatar
i bought new chevy rims 6-lug from a 98 chevy truck but my wheel studs r too short the rims fit the back axle but like half way not safely,,do i buy longer studs with new lug nuts ? wud a auto store have them? btw my truck is 6 lug drums,,thanks 2 any info.....
willz66 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9 Beta 3
