Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > General Chevy & GMC Pickups Talk
General Chevy & GMC Pickups Talk General Discussion Forum for all Chevy and GMC Pickups
Reply
Old 09-28-2004, 12:33 PM   #1
cssreb
Registered User
GMC 305 V6 Hard to find parts??
Hi Everyone..
I am looking at buying a GMC truck for the 305 V6 engine. I have heard the engine is very tough and one of the best engines in GM but I also heard that parts are hard to find.
I am looking for advise for -or- against using the GMC 305 V6 in my Truck.
Any advise would be greatly appreciated.
Thanks.. Russ
cssreb is offline   Reply With Quote
Old 09-29-2004, 01:10 PM   #2
Old77
Registered User
RE: GMC 305 V6 Hard to find par
This may be a dumb counter question but is there a such thing as a 305 V6? If you really mean a 305 V8 replacement parts are not really that hard to find for that since it was used for so many years and for so many applications. They are pretty common but just not really in high demand. However, if you actually mean the 4.3L v6 then you can find replacement parts but nothing much in the way of performance upgrades. Know what I mean? Of course, I could be dumb and there might actually be a 305 V6 out there that was used a long time ago. If there is, disregard and let me know if I'm mistaken.
Old77 is offline   Reply With Quote
Old 09-29-2004, 01:34 PM   #3
tech1
Registered User
tech1's Avatar
yes there was a 305 ci v-6 in the G.M.C. trucks. someone got me on that on a couple of years ago. I argued and argued till the old guy pulled out the book that looks like the first book ever written and sure enough there was a 305 v-6 and i felt really stupid. that man is my father-in-law and thats why you should listen to your elders.
tech1 is offline   Reply With Quote
Old 09-29-2004, 01:36 PM   #4
cssreb
Registered User
Hi Old77
Thanks for your response. I thought the same as you did but yes Virginia, there is a Santa Claus.. ah.. I mean a 305 V6. Take a look at the following web page: http://www.6066gmctrucks.org/305V6.htm
You are correct.. they were around a while ago.. the one I am looking at is from a 66 GMC. They considerer it to be a big block. They look a little weird as the spark plugs are on the inside of the cylinder heads by the intake instead of the outside by the exhaust.
My 65 Chevy has a striaght 6 (230) in it. everyone tells me to stick a Chevy V8 in it but then I have to hope the motor mounts line up, the gas pedel linkage fits/works etc.. my thought is this V6 will drop right in with minimal alterations needed.
Besides, everyone has seen a Chevy 350 but how many have seen a 305 V6
Again.. thanks for your response..
..Russ
Old 09-29-2004, 03:32 PM   #5
Old77
Registered User
Well, I learned something new today I can't give you any advice on the swap that you're talking about really. I personally would rather put a 350 in it but I'm sure you're right about needing to do some sort of modifications to get it to go in there having to do with motor mounts but I'm sure that it's able to be done. Maybe even Chevy Duty could help you out if you called up there to see what they say. Anyway, thanks for the info. Maybe I can win some money off this knowledge from my friends They'll think I'm crazy Having a 305 v6 would definitely be a unique application
Old 09-29-2004, 03:41 PM   #6
DrMike
Registered User
DrMike's Avatar
Hey Russ,
Yes that was a very good engine and a powerhouse of one at that. They were used only in GMC trucks and buses from 1960-1974. I'm afraid you will be unhappy to hear that the engine will not just bolt up in your 65 Chevy without doing some creative manufacturing of engine mounts. As far as clearing your steering column, it should not be a problem.
Parts are hard to come by for it. My church has a 66 GMC bus that we can't find parts for. Going to end up modifying it to accept a Big Block Chevy for the power. A 350 won't cut it.
Hope this helps.
Dr Mike
__________________
'58 Stepside
305 engine and 350 tranny
DrMike is offline   Reply With Quote
Old 09-29-2004, 07:44 PM   #7
72cheyenne
Guest
Posts: n/a
Hello guys,
I'm giong to type in lowercase now because my wife said I was yelling at you. I wasn't, but what the hey.
The 305 v6, yep, GMC only like was stated earlier 60-74.
It was designed to be an industrial engine, much like the tall deck big block chevy 366-454 cid engines. They produced lots of them during those years, however few made it into pick-up trucks. the poor gas milage and low rpms made it short lived. If you were going to use it for stump pulling or in a 2 ton with lots of gears, it would shine.
you would not be happy with the performance on the street.
Parts are available but expensive. The only way I've seen new parts is in the industrial field ie; farm equipment, tractor/big rig part suppliers...etc.
I've even seen a v12 in the same design as the 305 v6, 2 carbs, 2 manifolds, 4 heads, 4valve covers, 4 exhaust manifolds and then the normal waterpump, bellhousing and stuff.
The engine swap to the v8 from the 292 L6 is much simpler than you think.
By the way the 292 was an industrial engine too.
GOOD THINGS,
BRANT
Old 09-30-2004, 01:40 AM   #8
nsula_country
Registered User
Back when the Mayflower was sailing, my grandfather had a 1963 3/4 ton with the 305 V-6. Also, I was thumbing through an old Chilton's from the '60s and in the larger trucks C50, C60 there were even some 400+ CID V-6's. I'd love to see one personaly.
79 C20 Bonanza
350/400 4bbl Q-Jet
3.73 14-Bolt Corp.
nsula_country is offline   Reply With Quote
Old 09-30-2004, 11:21 AM   #9
tech1
Registered User
tech1's Avatar
i found some info on that 305e (and the 351e v-6)
compression ratio was 7.75 to 1
compression pressure was 125 p.s.i.
spark plugs ac,c45ns
plug gap is .035"
plug torque is 25 ft. lbs.
point gap is new-.019 old-.016
dwell 31-34 degrees
arm spring tension 19-23 oz.
firing order 1-6-5-4-3-2
timing without a.i.r. 7 1/2 degrees budc
with a.i.r. (mech. trans.) 2 1/2 degrees audc
with a.i.r. (auto. trans.) 7 1/2 degrees budc
valve lash (hot) intake valves 0.012"
exhaust valve 0.018"
engine idle speed (rpm) without a.i.r. 500-550
with a.i.r. mech, trans. 650
with a.i.r. auto trans. 550
bolt torque information (ft-lbs)
cylinder haed bolts 60-65
exhaust manifold bolts 15-20
intake manifold bolts 20-25
water outlet manifold bolts 20-25
rocker arm shaft bracket bolts 20-25
crankshaft hub bolts 180-200
note to set timing disconnect vacum advance line and plug it at idle speed.
compression pressure at cranking speed, wide open throttle-maximum variation between cylinders- 20 p.s.i.
Old 08-23-2006, 02:02 PM   #10
Pontiac1976
Registered User
Pontiac1976's Avatar
Send a message via ICQ to Pontiac1976 Send a message via AIM to Pontiac1976 Send a message via MSN to Pontiac1976 Send a message via Yahoo to Pontiac1976
Quote:
Posts: 25 GMC 305 V6 Hard to find parts??
Hi Everyone..
Thanks.. Russ
Question : what year were they made in be for 68 ??? Are they a straight 6 or V6??
because the only thing that come to mind is the 4.3 V6 witch looks like a 305 or 350 with the two back cylinders cut out.
Pontiac1976 is offline   Reply With Quote
Old 11-22-2006, 10:43 AM   #11
sls_06ion
Registered User
sls_06ion's Avatar
to give you an honest answer, I've got a 66 GMC 1/2 ton with a 351 v6, it would be great behing a 6spd tranny, but it's redline is 3700rpm and with a 4spd it's very impractical to drive around town, my advice swap in a 350, and yes parts are friggin expensive!!!
Tony
sls_06ion is offline   Reply With Quote
Old 11-24-2006, 03:17 AM   #12
283 man
Registered User
283 man's Avatar
Send a message via MSN to 283 man
Quote:
Tony
Yesterday after turkey day eating ,was driving home allways looking around for trucks like mine seen this 66 GMC 1/2 ton had the v6 badge on the side of the hood truck didnt look bad,just been sitting there for a while,I really hate seening trucks sat,yes 305v6 is hard to find.
283 man is offline   Reply With Quote
Old 08-15-2007, 02:52 AM   #13
billydonn
Registered User
My dad had 60-61 GMC 1/2 ton with the V-6. Very tough engine. It was great as a grunt parts getter around town. He made it into a wrecker. But NOT a good engine for today's cruising. Cool to HAVE one maybe... but not good to DRIVE much. I learned to drive a stick in that truck- come to think of it.
__________________
66 stepside
Tremec five speed
350 ci TPI engine
billydonn is offline   Reply With Quote
Old 08-25-2007, 01:27 PM   #14
64shortbed
Registered User
64shortbed's Avatar
the 64gmc long bed pickup im usein for parts has a 305 v6 in her sounds good only had her runnin 5 minits but oil presure good not knockin. im in western ks if anyone wants it? have not pulled it yet. and the tanny seems good too.when im get the shortbed put together ill have a good long wheel base frame too and other misc. parts oh buy the way if you didnt know already if you put the big v6 in youll have to put in the heavy springs too.
64shortbed is offline   Reply With Quote
Old 08-30-2007, 11:59 PM   #15
billydonn
Registered User
64 shortbed: What condition is the 64 GMC hood? I might like to have one of those.
__________________
66 stepside
Tremec five speed
350 ci TPI engine
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'60-'63 Chevy Truck Parts in MN- Buy/Sell/Trade colettesbro Truck Parts for Sale 59 Yesterday 10:12 PM
1960 - 1963 Chevy Truck Parts for sale in MN colettesbro 1960-1966 336 Yesterday 10:09 PM
parts are so hard to find generalmotor 1960-1966 2 12-13-2006 07:28 PM
Need parts & can't find 'em...???? BigRuffToys4x4 Truck Parts for Sale 1 10-21-2006 09:28 PM
can anyone help find parts?? 60chevySeth General Chevy & GMC Pickups Talk 0 08-13-2000 08:10 PM
Powered by vBulletin® Version 3.8.9 Beta 4
