Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 09-17-2005, 11:53 AM   #1
acipfeffer
Registered User
How to install the windshield easil
Hy guys,
another question another problem !!!
I should know how to install the windshield of my pickup 1951 ????
I have a two pieces windshield !!!
I already had some big problems by removing the windshield , was really tough, so i am a bit afraid of replacing the glasses.
I hope you can support me with some good ideas for doing a right job .
THanks a lot
Achim
acipfeffer is offline   Reply With Quote
Old 09-19-2005, 11:53 AM   #2
ttcodi
Registered User
RE: How to install the windshield e
These windshields were brilliantly designed for maximum frustration during installation.
You need to seat the glass in it's channel in the rubber off the car. Stuff a length of string in the other channel that seals around the pinchweld, and leave the ends hanging out to grab onto later. Place the whole thing outside in place and then pull the string from the inside to pull the lip around the pinchweld.
It sucks bad and will suck worse if you are by yourself.
ttcodi is offline   Reply With Quote
Old 09-19-2005, 07:13 PM   #3
Brian
Registered User
I agree, be sure and have a couple of helpers. The more hands, the less broken glass.
I am confused why you found removing the windshield to be difficult - it is really easy if you cut the rubber around the windshield inside the cab, and then tear off that piece, and then just push the windshield out. Maybe you tried to save the rubber? If so, forget it, buy new. And I suggest Steele Rubber products, if you want the windshield to not leak.
Brian is offline   Reply With Quote
Old 09-22-2005, 09:03 AM   #4
PakFanWV
Registered User
I finally got the courage up to install the new windshield glass I ordered from Chevy Duty, along with the new rubber, of course. After all the other work I've done, I expected this part to be possibly the hardest yet. Not true!
I installed both glass pieces into the rubber first, then "roped" it. I used (thin) plastic clothes line, THANKS, VWNATE!, and NO lube at all. I placed the new windshield into the opening and gently bumped the corners tight in the hole. I then went inside the cab and pulled the clothes line out with no problem at all! I believe the entire process only took me an hour, and the new glass is fantastic!
Thanks to everyone's tips, hints and advice on this forum I did this job alone, believe it or not! I sure couldn't - and still can't!
But here's to everyone who's advice I incorporated into the work - THANK YOU! I love this forum, guys
PakFanWV is offline   Reply With Quote
Old 09-22-2005, 07:41 PM   #5
vwnate1
Registered User
vwnate1's Avatar
RE: install the windshield
Glad to hear it went in O.K. , mine was a b*tch lemme tell ya and then it leaks like a screen door too .
Just to day I was out chasing parts for the Metropolitan Nash (it's my rain car) and stopped in to The Trukc Sohp , they had the correct thickness windshiled glsses on sale for $41.00 ea so I bought a pair and will order up the good quality Steele Rubber Products grommet next week as Chevy Duty let me down on this part , the only part I've had any troubles with from them .
This glass is made in Taiwan (?!)
Did you use the steel center clothes line or just the plastic one ? .
__________________
-Nate
' PASSION ' :
There are many things in life that will capture your eye , very few will capture your heart ~ those are the ones to persue .
Those are the ones worth keeping .
vwnate1 is offline   Reply With Quote
Old 09-23-2005, 08:12 AM   #6
PakFanWV
Registered User
I went ahead and got the kind with the steel "cable" running through it. I figured that way if the line happened to break while pulling it out - in case it was a REALLY tight fit - I could still get the edge of the rubber up enough to pry out any remaining plastic line that may have been otherwise left in the channel. I honestly couldn't believe it when I went back outside after pulling the rope and just VERY slightly bumped in the bottom corners with the heel of my hand! It seemed as if that was all they needed - everything seated correctly the first time, no bulges or bumps anywhere, and it even fit nice and tight at the top center on the outside. I'd read here that if you put it in upside down it would pucker up and make a nice little funnel to take rain water right into the cab for you.
Anyway, thank you again everyone for all the hints - and I hope my story helps someone else get it done...
Old 09-25-2005, 02:12 PM   #7
vwnate1
Registered User
vwnate1's Avatar
RE: Right Side Up ?
D'OH ! I wonder if I did this on my '49 since it never leaked a drop with the original grommet and cracked glass in there , it now leaks like a sieve and I just bought new glass again , how to tell which way is up on the rubber ? .
-Nate
__________________
-Nate
' PASSION ' :
Old 09-25-2005, 07:47 PM   #8
PakFanWV
Registered User
RE: Right Side Up ?
Nate - sounds to me like that's what may have happened to yours. Here's what I did... and remember, I've NEVER done anything like this before:
When I took out the old glass and rubber, I got in front of the truck and looked at the windshield setup. Just looked at it to ponder how NOT to put it in upside down. (I didn't want to go through this process twice!) Anyway, the windshield pieces are slanted both backward (relative to the truck) and slightly upward relative to the lowest point on the rubber's center point. Kinda like butterfly wings. When I laid out my new rubber gasket (before putting the glass in it) if you lay it out carfully, place the center of the rubber perfectly flat on a bench or table. When you do that, look carefully at how the outer frame of the rubber wants to come off of it. The TOP (and the bottom for that matter) of the rubber will appear as a very slight " V ", with the rubber again going out and up from what would be the top of the windshield. If it's upside down, it'll look like a " ^ ". This means that when you lay the glass in it and pop it into the window opening there'll be a bit of "extra" rubber that can't be taken up anywhere else in the process, so it'll make that "pucker-out" problem happen and shape a nice little funnel at the top-center of your new glass.
On the same subject, if you get a piece of windshield rubber, lay it out and it lays perfectly flat, get a new one. That'll cause the same problem - if not worse...
Hope that helps! That's the best way I can explain it...
Good luck!
Old 09-28-2005, 07:58 AM   #9
vwnate1
Registered User
vwnate1's Avatar
RE: Right Side Up ?
Well ;
I read this a buncha times and I _STILL_ can't make any sense out of it so I printed it out and will lay it on the hood when I replace the rubber , I need to do this sioon but my other cage is down for repairs so I might be driving a leaky truck all winter again .
-Nate
__________________
-Nate
' PASSION ' :
Old 09-28-2005, 09:21 AM   #10
PakFanWV
Registered User
RE: Right Side Up ?
____________ ____________
\ ---------v--------- /
\ I /
\ I /
\________ I ________/
---------v---------
Ok, that's the best I can do to show you how it should look... with this perspective, you are looking straight on to the windshield. I hope this will help... now remember that the angles in my "drawing" are VERY exaggerated. In real life they will be MUCH more subtle - so look carefully!
(That's what I mean by "butterfly wings"... )
Old 09-28-2005, 09:22 AM   #11
PakFanWV
Registered User
RE: Right Side Up ?
Well, THAT didn't work.... I'll try to do an attachment later. Sorry for that goof-up!
Old 09-29-2005, 10:52 AM   #12
vwnate1
Registered User
vwnate1's Avatar
RE: Windshield Install
I didn't understand any of that but what the hey , I went ahead and ordered up a nice new rubber from Steele Rubber Co . , as it turns out they don't mention top or bottom orientation but they _do_ have a nifty printable PDF installation sheet you all should go get (free) it makes it look like a normal straight forward installation like I've done many times before .
Wish me luck ! hopefully no more water leaks .
I ordered up some windlace and a new cowl vent seal too , will report on them when I install them .
-Nate
__________________
-Nate
' PASSION ' :
Old 09-30-2005, 03:57 PM   #13
ltcmikem
Registered User
Post RE: Windshield Install
Nate -
I've bee to the Steele Rubber Co. web site and scrolled through their online catalog. I wasn't able to find any rubber sets/applications for AD trucks. Scratching my head here... what am I not doing right?
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
__________________
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
ltcmikem is offline   Reply With Quote
Old 10-02-2005, 09:59 AM   #14
vwnate1
Registered User
vwnate1's Avatar
RE: Steel Rubber Co.
I dunno ~ I had a time with it too , it's prolly simple to computer heads , I clicked on something on the left side menu then it gave me a popup to select my make (Chevy or maybe it was GM trucks) then I had to scroll down through lots and lots of stuff before finding the windshiled rubbers , take your time , if _I_ could find it so can you ! sorry I'm a 'puter dummy and cannot describe well what to do .
-Nate
__________________
-Nate
' PASSION ' :
Old 10-02-2005, 07:05 PM   #15
ltcmikem
Registered User
Post RE: Steel Rubber Co.
Thanks Nate... I'll take your truck knowledge and willingness to help us over a bucket full of 'puter savy any day.
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
__________________
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Windshield installation E Smith 1960-1966 5 09-24-2008 04:51 AM
Windshield rubber tip coilover 1947-1954 4 07-25-2008 06:00 PM
Good windshield glass--bad windshield rubber fasteddie1017 1947-1954 18 07-24-2008 09:09 PM
Windshield trouble Chiro 1947-1954 5 07-06-2008 09:54 PM
Installing bedwood/installing windsheild max 1960-1966 1 12-17-2000 06:27 PM
Powered by vBulletin® Version 3.8.9 Beta 4
