Installing a C-Notch
Discussion in '1947-1954' started by Ricos54, Jan 7, 2014.
  1. Ricos54
    Ricos54 Member
    CA
    Thank you Zig, you are always a positive influence. Here a few more things I have done. Been a little busy and haven't done as much as I have lately:rolleyes:
    Received my light bezels but had to cut them down to fit my truck
    Finished my gas line to my mechanical pump
    Also received my flush mounted LED lights for my roll pan
  2. Ricos54
    Ricos54 Member
    CA
    Also finished my tilt bed floor
    also getting ready to build a fiberglass console for the first time, made the template out of cardboard
    Then the biggy, lol. Some said it would not work, some said they don't like the rubber and look. But yeah this is what I like :cool:
    My wheels and tires. 20 x 9 Octane fuels and 255/45/20 420s. nittos
  3. Ricos54
    Ricos54 Member
    CA
  4. Ricos54
    Ricos54 Member
    CA
  5. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Gotta say it again.... You, sir, are doing some outstanding work. Thanks for the update!!
    Damon
  6. Ricos54
    Ricos54 Member
    CA
    Thanks Damon, really appreciate it man. Here's some things I did this weekend:D
  7. ccharr
    That is looking so good. Thanks for posting the update.
    So much hard work and dedication there ! .
    Keep it up and the pictures too .
  9. Ricos54
    Ricos54 Member
    CA
    Thanks guys, I'm doing my best to get things done :D
    Here's a little more I've been doing.
    Have an idea what my truck is going to look like
    Found some really nice running boards in perfect condition
  10. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Looking good Rico! Love the front end photo.
  11. Ricos54
    Ricos54 Member
    CA
    Thank you Roadster, here's another one I also started building my center console once it's made I plan on fiberglassing it. :)
  12. Ricos54
    Ricos54 Member
    CA
    47-53 Splash aprons with 47-53 bed on top of 54 frame
    Console done with shifter linkage in
    Welded my hood together
    And putting my engine together getting ready to start it for the first time. Hook up my throttle linkage
  13. Ricos54
    Ricos54 Member
    CA
    Gas pedal hooked up and brake pad in place
  14. Zig
    I LOVE IT!!!!!! Love the console you have going on there! Awesome work!!!
    And of course, who the heck doesn't like CHROME! Beautiful power plant!
  15. Ricos54
    Ricos54 Member
    CA
    Well could not help myself. Lol thinking about all the body work I had ahead of me I decided to buy the fenders. Bought both sides brand new from a guy I know for $250 could not pass it up.
    Installed my power steering pump and after 4 trips to the parts store got all my belts to run the engine
  16. Ricos54
    Ricos54 Member
    CA
    I also finished my gas line. Tried to run it the traditional way, but ran into a problem with the A/C compressor being above the intake so I had to find another way. I made my own setup to accommodate the dual outlet I had with the Holley 570 Street Avenger, so this is what I came up with. Also I Mounted the MSD setup and cut all my spark plug wires and installed the radiator :)
  17. Ricos54
    Ricos54 Member
    CA
    Couple more pictures of my custom setup I made. -6 an fitting with steel braided line , Holley regulator and gauge. Go's so show you, if you run into a problem there's always another way to get the job done. I just did research on the net to see all the options I had and that's when I came up with this solution..
    Pretty happy the way it came out.:D
  18. ccharr
    Thanks for keeping us updated on your progress with all the photos.
    Keep up the great work.
    Charles
  19. Ricos54
    Ricos54 Member
    CA
    Mounted my battery and made some A/C vents
    K&N filter
    Mounted a flex a lite 16" electric fan. Fab some mounts for it. Hopefully starting my engine tomorrow for the first time. I ordered a flexible hose for my radiator but won't be here till next week so I went to the junk yard a found a rubber radiator hose for $1. Lol
  20. Ricos54
    Ricos54 Member
    CA
    Also mounted my overflow
