  1. Coach529
    Coach529 Member
    Jamestown, ND
    I have a 4 barrel intake and carb right now, but would like to find a 3 deuce setup at some point.
    I have a visor as well, but am not 100% sold on how it looks.
  2. Coach529
    Coach529 Member
    Jamestown, ND
    Think I have all my bases covered. I just have a couple loose ends.
    Any suggestions on what to use as a throttle pedal?
    TH350 transmission to a 4 x 4 blazer rear end. Any idea's on a approx driveshaft length or a suggested donor?
  3. Guest5979
    Guest5979 Guest
    driveshaft
    The driveshaft I used was out of a 90s chevy impala $22.00 out of a pick a part junk yard np cutting just new u joints
  4. MN Jim
    MN Jim Member
    Andover MN
    Driveshaft
    Mike, I put basically the same driveline as you in my 3600 and I used a driveshaft out of a early 90's regular cab Chevy pickup. Had to change the yoke to TH 350 yoke and it bolted in.
    Jim
  5. ol' chebby
    Spoon gas pedal is the easiest.
  6. Coach529
    Coach529 Member
    Jamestown, ND
    Thanks....good to know!!
    Looking Good Coach !
    I think the frame boxing was a terrific idea , you might consider doing that for the steering box area too .
    Not going to replace the timing chain , sprockets and cover seal ? .
  8. Coach529
    Coach529 Member
    Jamestown, ND
    Spent some time today cleaning up the frame for paint.
    63 years of grease, oil and dirt covered the drivers side. Between a wire wheel on my 4-1/2" grinder, a putty knife and a healthy combination of degreaser and some hot water I got it clean.
    I fought rain showers all day....
    After the degreasing and cleaning I sprayed the frame down with KBS Rust Blaster and rinsed it again with hot water.
    I rolled it into the shop and let it dry for a couple hours and brushed on a coat of KBS Coatings Satin Black. Turned out pretty good. I will follow up with a couple more coats over the weekend.
    All my gaskets and misc parts showed up for the 350, so I hope to start buttoning that up this weekend as well. Maybe even get it painted!!
  9. Guest5979
    Guest5979 Guest
    looks good
    was there any issues when you put in the drop axle and did you have to change the master cylinder?
  10. Coach529
    Coach529 Member
    Jamestown, ND
    NO issues at all with the axle or install.
    I did install a modern MC with prop and residual valves. Very please with the set up.
  11. Coach529
    Coach529 Member
    Jamestown, ND
    Crazy busy weekend......but the motor is in primer.....
  12. Guest5979
    Guest5979 Guest
    color
    what color are you going to paint engine? if your going to keep engine stock looking i have a pair of chevy script valve covers
  13. Coach529
    Coach529 Member
    Jamestown, ND
    Chevy Orange. What color are you valve covers?
  14. Guest5979
    Guest5979 Guest
    valve covers
    patina chevy orange a new coat of paint and they will look nice
  15. Coach529
    Coach529 Member
    Jamestown, ND
    Sent you a message!!
  16. Coach529
    Coach529 Member
    Jamestown, ND
    Motor is now orange......
    And my Lokar shifter showed up.......whoohoooo
  17. Coach529
    Coach529 Member
    Jamestown, ND
    I took the day off work and got some stuff accomplished.
    I ended up damaging the rear brake line when I put in the tranny cross member, so I re did that. The passenger front brake line was routed next to the old tranny cross member, so that had to be redone as well.
    I drilled the holes and bolted in the new transmission cross member. I bolted on the new aluminum intake to the SBC, as well as installed a new oil pan gasket.
    I installed the stall converter on the TH350, and was ready to bolt the flex plate to the engine when I realized the bolts are 7/16" fine thread. None of those in my bolt bin.
    Oh well.......I will get it done tomorrow and toss the motor and tranny in.
    My HEI Distributor and plug wires showed up from Speedway. Sure nice having those guys only 1 shipping day away.
    I am running an aluminum water pump, measures like a short pump. I picked up a pulley today at the junkyard, but it looks like I would need to space out the pulley 5/8" to match the crank pulley. Does not make sense. The pulley came off a mid 70's GMC truck with a SBC.
    Any advice on mufflers? I plan on piecing together the exhaust myself. The local muffler guy wants almost $500. I can weld and bend pipe.......only concerned about flaring.
  18. Zig
    Glad to see you back on here with your great photo progress shots! I know someday I will be installing a V8 (hopefully 283) in mine, and seeing what your doing is a great visual "how to". Thanks for taking the time to do this for us.
  19. Coach529
    Coach529 Member
    Jamestown, ND
    You are very welcome!!
  20. Coach529
    Coach529 Member
    Jamestown, ND
    Pretty good day despite distractions and multiple trips to the hardware store.
    Got the bolts to mount up the flex plate and got the tranny attached to the motor.
    Everything went together fairly smooth.
    I did overlook during mockup that the fuel pump would hit the frame. A quick cut with the jig saw and some grinding and it was fixed.
    Off the jack stands and pushed outside so I could clean out the shop!!
