Never again
Discussion in '1947-1954' started by coilover, May 17, 2014.
  1. Bill Hanlon
    European guys must be different than us Yanks. At least you'll read a map.:)
  2. skalywag
    skalywag Member
    Nashville
    My first (and only) VW was a 1968 Karmann Ghia. A wonderful car to drive and I drove it for 200K miles on it's original engine. I learned much from that machine - like valve adjustments (every 3K), oil changing (every 3k), belt adjustment techniques (shims - really). The earth was taking it's toll an her when, after hitting a chuck hole, the drivers seat fell thru the floor to the pavement below. A wedged in piece of angle iron got me on my way - and remained there until I sold the engine (and H 1500 single port) out of her to a friend and another person got the carcass.
  3. DeadZoneTruckin
    DeadZoneTruckin Member
  4. Bill Hanlon
    Sign that guy up for the pit crew!
  5. coilover
    One thing about those German machines--they don't go down without a fight. Now the generator is not working is kaput for sure. Went the mile down to the VW shop and they said it could be changed in the car but it was far easier TO PULL THE ENGINE. Keep telling me about how easy they are to work on. It's a 1970 so we replaced generator with alternator which also took a new mount stand. 225 bucks and it's ready to be stabbed first thing in the morning. The generator pulley has me baffled; no matter how many or few washers you put between the pulley halves the belt is loose enough to tie a knot in until you turn the engine a couple revolutions and then it gets tight. ??
    They're *Different*
    So you need to approach the mtce. & repair angle differently ~ once you learn to do this , old VW's are simple to work on....
  7. DeadZoneTruckin
  8. ccharr
  9. Blueflame236
    Beetle truck
    Thanks fore sharing this link Joe. I loved the way he managed the design and Tech. solutions.
    Martinius.
