Carb question
Discussion in '1947-1954' started by 51papy, Aug 10, 2014.
  1. 51papy
    51papy Member
    Osawatomie KS
    I have a 58 235 and a Rochester C it came on the motor and a Carter YF both need rebuilt. Is there any advantages to using one or the other. The Carter is set up to take the chock and throttle controls but the bracket looks like it would fit on the Rochester
    Papy
    Carby Choices
    I'm assuming you meant ' B ' series Rochester .
    The YF is vastly superior and if you're careful in overhauling it , you'll instantly notice the improvement .
    Do not dispose of the Rochester until you're 100 % satisfied with the YF .
  3. 51papy
    51papy Member
    Osawatomie KS
    Thanks Nate
    There is some light at the end of this 10 year project.
    Papy
