52 Two ton with widow makers
Discussion in '1947-1954' started by The_51, Jun 7, 2018.
  1. The_51
    The_51 Member
    Ellsworth United States
    Im currently interested in buying a very nice 52 two ton truck with 20 inch widow maker split rims on it. The fronts are a 5 lug wheel. Im wondering if anyone knows of a modern one piece 19.5 inch rim that would fit this truck. Then i could run modern tube less tires and be a little safer as well. I know several folks that have been bit by these through the years. Thanks Jake
  2. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Seems like they used to put 19.5", 5 lug wheels on a few motor homes. Probably hard to find. May have to use a custom wheel manufacturer. Like Stockton Wheel.
    You might try the forum at the "American Historical Truck Society".
    American Truck Historical Society
    Steve.
  3. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Don't know if these dimensions are right?
    WN89340J
  4. Bill Hanlon
  5. The_51
    The_51 Member
    Thank you all for your reply's, you have given me some good information to continue my search!
  6. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Modern Dodge Ram pickups have 20", 5-lug steel spare wheels. Not sure of bolt circle, hub diameter, or offset as it pertains to your application though. They look >exactly< like this (albeit 6-lug, sans hubcap-clips) 20" steel wheel.
    Zig likes this.
  7. Zig
    When-oh-when will we ever see your truck surrounding that wheel... #wink#
