How do you lift your pickup
Discussion in '1947-1954' started by wokri, May 30, 2020.
  1. wokri
    wokri Member
    Germany
    Hello,
    how do you lift your pickup on a lift? If you will answer, please put some pictures in your answer.
    Wolfgang
  2. e015475
    e015475 Member
    Show Low AZ
    If by 'lift' you mean a two-post lift, then you need some extenders for the lift's arms.
    These are pretty common in the states where there's lots of trucks with full frames. I imagine they'd be relatively rare in Germany.
    Here's some for a Rotary brand two-post lift-
    https://www.amazon.com/Rotary-T100271-Adapter-Extension-Newer/dp/B01KKECWSS
    For safety sake, use lift extenders designed and manufactured by the lift manufacturer.
  3. wokri
    wokri Member
    Germany
    Thank you for your answer.
    Wolfgang
    I use a hydraulic trolly jack and some good quality jack stands .
    I life the front by the axle and the rear by the middle of the rear banjo....
  5. coilover
    Our 2 post Rotary lift has flip up pads that reach the frame before the arms hit the running boards. The 4 post Rotary one just drives the truck onto it. It has the rolling jack feature so one can do anything on it that you can do on a 2 post like brakes or suspension work.
  6. wokri
    wokri Member
    Germany
    Ok, thank you for your pictures, but these kind of flip up pads I can't get them here in Germany.
    Wolfgang
  7. Bill Hanlon
    Like this?
  8. Kossi
    Kossi Member
    Baden Württemberg, Germany
    Hallo Wokri,
    da haben wir wohl das gleiche Hobby...
    In welcher Gegend bist du zu hause?
    Gruß
    aus Baden
    Michael
