Need help finding springs
Discussion in '1947-1954' started by 51gmc100, Feb 17, 2022.
  1. 51gmc100
    51gmc100 Member
    Dandridge, Tennessee
    Hey all, I have a 228 gmc engine and I need to find the two springs that connect to a pin on the block to the accelerator pedal linkage under the manifold area. Thanks
    vwnate1 likes this.
    Welcome, maybe a link to an image of what you need ? .
    The Old Car Manual Project has quite a few illustrated factory shop / parts manuals, maybe you can find a picture there and post it up? .
  3. Bill Hanlon
    Probably the two springs shown here, index 8.5720. Looks like people had problems with them back in the 50s. See "Accelerator Control Rod Kit" at the bottom of the page.
    The inner spring is GMC part # 593599 and the outer spring is 3650830. No size descriptions in the Master Parts Book.
    You could probably find suitable springs at a good hardware store. If you'll buy me an ice cream cone the next time I see you, I'll take the springs off of my '52 GMC 150 and measure them for you.
    vwnate1 likes this.
    And, there you go ! .
    Accelerator and clutch/brake return springs are special, the wire used is thin and they tend to have more windings than you'd expect, this allows them to work well without having too much tension .
    Now you know what the group number is, you should be able to find the part # in the other part of the parts manual .
    Maybe Dorman has something ? .
    Lots of older foreign cars with multiple carbys use springs like this, maybe look up under Porsche 912 1965 or Weber carby parts ? .
    My old Mercedes Diesel use similar springs and they just go *poof* every s often so I carry spares salvaged at junkyards .
    I also find them new at Auto Jumbles....
    DO NOT use a strong spring here ! .
  5. Bill Hanlon
    I listed the part numbers Nate.
    OOPS ! duh .
    I should have known Bill .
    Good luck hunting Newbie .
  7. 51gmc100
    51gmc100 Member
  8. Bill Hanlon
    Might be a couple of days before I can get to it. My daughter is coming to stay until Tuesday.
    Carby return springs : carburetor return spring - Google Shopping
    Once you know what size this may help you .
    I tried googling both part #'s, no joy .
    MotherTrucker, AKA Joe M. who's on here may well have some N.O.S. ones for sale, give him a try too .
  10. Bill Hanlon
    GMC specific, although the Chevrolet Master Parts Catalog for 1929-1954 lists all models of 1937 Chevy use the same 593599 spring. Its description is "pull back (2 1/2 approx. free length - two hook ends)".
    vwnate1 likes this.
  11. Bill Hanlon
    First, let me say that I have no idea if my springs are original equipment, but the pressure required on the gas pedal seems reasonable to me.
  12. 51gmc100
    51gmc100 Member
  13. Bill Hanlon
    Forgot to put it in my earlier post. The spring wire was 0.055" diameter on both springs.
  14. 51gmc100
    51gmc100 Member
    Just what I needed. I’m ordering springs from McMaster Carr now Thanks again for getting me the information bill When ever I get back through Texas I owe you a few beers.
    RidesWithYah likes this.
  15. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Post up the McMaster-Carr PNs you used, especially if they worked well for you? Thanks!
  16. 51gmc100
    51gmc100 Member
    Sorry so long before I could get back to you. Before I got on the phone to McMaster I decided to go to ace hardware and matched up some springs from their supply of springs. I didn’t get the number but they are easy to match as close as you can for pull strength and size. They are ALOT cheaper too. Cost me about 5 bucks
