GMC radiator support
Discussion in '1947-1954' started by 3/4 gmc 1952, Sep 27, 2011.
  1. 3/4 gmc 1952
    3/4 gmc 1952 Member
    Claremont, NH
    Hey all you G men. Can someone post a picture or too showing how the radiator support mounts to the frame. I am not entirely certain I have the right support after speaking with deadzonetruckin. Thanks
  2. DeadZoneTruckin
    DeadZoneTruckin Member
    Mounts to the front the X member with a U bolt & a series of shims & springs.
  3. Zig
    Yup~ That's what it looks like, and that's how I put mine in. Radiator support frame is sandwiched in between those parts. Great picture, DZ!
  4. 3/4 gmc 1952
    3/4 gmc 1952 Member
    Claremont, NH
    OK Here is what I have one picture of the bottom of the radiator support, two pictures of the frame crossmember at the front of my truck. What have I got??????
  5. Zig
    The first picture looks like a surround from some other vehicle. The u shaped bolt should go through from side rail to side rail, not front to back like the one you show seems to be set up for.
    I'll get pictures of mine tonight and show you how mine mounts.
    I'm sure by then someone will have set things straight, however.
  6. DeadZoneTruckin
    Hard to tell by the picture of your radiator support but, it looks like you have a Chevy radiator support & the GMC support is completely different.... they will not interchange.
    If you do not have the correct GMC support... you will be needing everthing that is GMC specific ....circled on the schematic.
    Here is the complete GMC radiator support assembly with the correct mount.
  7. spika
    spika Member
    Central Montana
    I'd say you'd be hard pressed to find any better pictures and info than these guys have produced!!! I was not aware that the Chevy's were not interchangeable with these parts...
  8. 3/4 gmc 1952
    3/4 gmc 1952 Member
    Claremont, NH
    Tom, you are absolutely correct. These pictures definitely show....I have the wrong support. So DeadZone I am sending a PM your way. Thanks guys!!!
  9. Zig
    See? They did help you before I could post!
    But I will anyway, just for the heck of it! :D
    Hope these help even more~ (Had to through in another picture of the 228)
      File size:
      190.1 KB
      911
      File size:
      139.6 KB
      890
      File size:
      126 KB
      851
      File size:
      133.3 KB
      842
  10. 3/4 gmc 1952
    3/4 gmc 1952 Member
    Claremont, NH
    Thanks Zig for taking the time. No such thing as too many pictures when trying to figure something out. How do you like the alternator set up? Did you use a specific alternator? Any advice on the install if I go that route. Not sure why I would need to but good to know about it just in case.
  11. Zig
    The alternator was part of that 12 volt conversion thing. I believe it was out of an 80's something firebird? The main thing is that it has the single wire lead. The arm was from O'Realllly. I used the old genny adapter plate with the alternator. It took a bit of "crafting", but it finally fit and works fine.
    Taking pictures of my truck got me back out there. I actually spent most of the day doing some wiring.
