'53 Chevy truck- Crazy Adventure
Discussion in '1947-1954' started by Frank64, Jun 12, 2012.
  1. DeadZoneTruckin
    DeadZoneTruckin Member
    We installed new windshield glass a few months ago on my '49....
    We used the Steele Reproductions rubber gasket ..... it fit better than the Chinese ones... except there is still that nagging bad fit at the tight turns at the bottom of the pillars.
  2. Frank64
    Frank64 Member
    I hope to be able to install without much trouble.
    I installed and uninstalled 10 times the windshield ... is not very nice :).
    I saw your picture, and you've had the same problem.
    I'm beginning to suspect that require a decrease in the central part of the glass,
    maybe 2 mm for each glass......??
    I'm realizing there's nothing :)
    We'll see :)
  3. Frank64
    Frank64 Member
    Some parts rechromed, just handed to me
    Other parts rechromed
  4. Blueflame236
    Wonder if this would work out ?
    Guys.
    It seems the Steele fabricated rubber has the same problem as the chinese one i understand wich means that they need a responce on there product from the USA wich does`nt work well either. So my question is where to buy a rubber that fits excactly in the mean time ?
    Would it be posseble to get a good tight solution when cutting the rubber in upper/down senter and use fast drying black building clue/silicon (rubber to steel) so the rubber sits tight against the inner window frame as it is covered with the outside window trims ? Then using building black clue/silicone where the cut is made ? Just wonder if this would work out ?
    Martinius.
  5. skipper
    skipper Member
    Very nice work and build. You have much talent. What shop is doing your chrome?
  6. Frank64
    Frank64 Member
    Thanks Skipper.
    The shop that did my chrome is very expensive. For those pieces that you see in the picture (Only the first photo, not the second) and the inner windshield molding
    I waited 3 months and I spent 390$
    Frank
  7. Blueflame236
    Suggest that you give them a call and ask them to send you a new one or ...!
    On behave of all truckowners you could give them a call and tell them in a polite way that many people are buying this unuseless shit. They could either give you a new one without a defect or pulled them selves together and make a product that is usefull. As many truckowners neeed these rubbers to buy in the future and many complains will come elsewhere.
    Martinius.
  8. Zig
    Frank~ Your truck is BEAUTIFUL!!! That chrome looks fantastic, as far as I'm concerned. Pricey, yes~ But WOW!!!
  9. DeadZoneTruckin
    I am not really in a position to complain as the 2 pieces of glass, the gasket & installation labor were all free as my insurance company paid for everything on my 100% full glass coverages.
    The windshield tech installer that showed up to replace the glass was an old guy that chewed tobbacco ... we got along great & I had fun helping him through the installation process.
    I usually have to do everything by myself on all my trucks so.... it was nice for someone else to show up & help maintain my trucks while I sat in the shade & "supervised " the windshield installation.
    I will end up gooping up & sealing the entire windshield gasket with this stuff anyway...
    http://www.amazon.com/C-R-LAURENCE-CRL7711-Windshield-Sealant/dp/B000KZUZXC
  10. Frank64
    Frank64 Member
    Thank yo so much Zig :).
    I hope to finish soon :rolleyes:
    Frank
  11. Frank64
    Frank64 Member
    More parts arrived this morning.
    Now I get to work and soon there will be new updates
  12. Frank64
    Frank64 Member
    Hello to all,
    after deciding the best place (for me, under dash, driver side)
    to fix the fuse box I created a bracket because I did not like leaning
    FUSE BOX LOCATION
    AmericanAutowire 15 way kit
  13. ccharr
    Frank,
    The progress is great, I really like what you have done so far with rebuilding your truck.
    Was wondering why the use of a drywall screw to hold your bracket for the Electrical Fuse block. Do you have access to some stovebolt screws or pan head or hex head, ( http://www.boltdepot.com/fastener-information/Type-Chart.aspx) or other than? Was just wondering seeing all the chrome plating you have done so far.
  14. Frank64
    Frank64 Member
    Thanks Ccharr,
    the support screws are all hidden from the Dynamat insulation
    and side panel. However the ones you see now is temporary screws :).
    I am currently preparing the firewall and the floor before
    installing the Dynamat
    Frank
  15. Raz76
    Raz76 Member
    -okc-
    Are you going to Dynamat the entire cab? If so, how much did you get to cover entire cab? Good work so far.
  16. Frank64
    Frank64 Member
    Hi Raz76,
    I put the dynamat only on the inner firewall and floor.
    In the doors, below the top, under the seat bench and in the rear of the cab put another type of insulating.
    Frank
  17. Frank64
    Frank64 Member
    Hello everyone,
    some little updates :).
    I started to install the dynamat insulation and pedals, and for the parking brake pedal I bought a Dimmer switch Pad and I thought to do so
    I separated the two pieces
    Assy...
    I have also modified the top cowl vent drain hose to avoid that water falling on the engine.
    No need to make any holes I used the existing
    Now the drain hose comes out the bottom next to the passenger door
    I hope that these solutions are helpful for someone. If you have questions do not hesitate to ask
  18. Frank64
    Frank64 Member
    More pics today
    Wiring harness assembly...will work very long
    I chose to route the wirse down and pass them within the frame rail
    Details. Today I tought to install the door but I decided to wait until I finish
    the wiring harness
    I installed also the rear shockwave and rear brake line
    Latch panel with rechromed parts
    Throttle and kickdown cable installed
  19. Haasman
    Haasman Member
    N. CA, south of SF
    Wow! Nice work. Gonna be great!
    Haasman
  20. Zig
    MAN! That wiring sure looks like FUN!!! ;)
    I like what you did with the parking brake!
