Sway Bar Picture
Discussion in '1947-1954' started by doug49, Jan 30, 2013.
  1. doug49
    doug49 Member
    Anyone have a picture of a front sway bar installed on a 49 (50 or 51) pickup that could be posted. Thanks.
  2. fab51
    fab51 Member
    Central Missouri
    How soon do you need it? I can get one, but the '51 is at the farm and it may be a couple of weeks before I get it home.
  3. doug49
    doug49 Member
    Sway Bar
    That would be good. When you get it please post it.
  4. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    I have some pics of an original 49 panel truck sway bar installation.
  5. Blueflame236
  6. Greg_H
    Greg_H Member
  7. fab51
    fab51 Member
    Central Missouri
    I hope these will help you...
      File size:
      332.5 KB
      352
      File size:
      245.6 KB
      343
      File size:
      270.9 KB
      350
      File size:
      266.9 KB
      334
      File size:
      406.4 KB
      308
  8. ccharr
    Thanks for sharing those photos Tim.
    Charles
  9. Greg_H
    Greg_H Member
    There are 2 styles of original sway bars for the AD trucks. The first one shown is the earlier style and better fits the lever shock trucks? It has the end link mounts at the leaf springs. The later style just shown has the end links that clamp around the front axle.
    Tim's Truck
    Um Tim ;
    I hope you know your springs are shot.....
  11. fab51
    fab51 Member
    Central Missouri
    Springs shot?
    What makes you say that, Nate? I've put many miles on the truck over the last (almost) 20 years and have never noticed anything out of the ordinary.
  12. vwnate1
    Flat Springs
    Because they're flat ~ leaf springs are supposed to be arched .
  13. fab51
    fab51 Member
    Central Missouri
    :) Not to be argumentative, but... Check out 4WD brand "F" F-250 and F-350's, at least up through 1997. They have a solid front axle with leaf springs that are either flat, or reverse curved.
    As long as it isn't sagging or unstable, I'm not in a financial position to worry about it. :(
  14. vwnate1
    Leaf Springs
    As long as it doesn't bottom out , you're good to go .
