  1. Coach529
    Coach529 Member
    Jamestown, ND
    Just a Cragar chrome center cap.
  2. Zig
    I love the work you're doing Mike. Having that talent to weld really opens up the possibilities. I don't think that will have any problems with applied torque!
  3. Coach529
    Coach529 Member
    Jamestown, ND
    Punch list is getting smaller:
    * Mount front shocks
    * mount master cylinder
    * Run brake lines
    * bleed brake system
    ********Test Drive*********
    * Install bed
    * Tailights
    * Trique Latch Install
    * Weather Stripping
    * Stereo
    * Seat Rebuild
    Boxing The Frame
    I'd love to have this done to my frame , I want it otherwise stock but frame flexing is an issue when I hit the twisty bits in the canyons....
  5. Coach529
    Coach529 Member
    Jamestown, ND
    Pretty easy to do Nate.
  6. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Keep punchin' out the punch list! This is an awesome build. You've played no small role in lighting a fire under me to get back to work on my truck. I've been out in the garage the past two days...
    Damon
    Welding
    For you , yes .
    Me , not so much .
    I can do many things but body work and welding are beyond my grasp .
    I can just imagine how much better it'd handle those canyons once the frame was boxed in.....
    I love surprising others in my old 6 Bangers , I don't actually go fast but no one who doesn't know me , expects to see some old battered rig come flying down The Angeles Crest Highway :D .
  8. Coach529
    Coach529 Member
    Jamestown, ND
    Sorry....updates have been slow. There has been very little progress lately, and nothing worth photographing!!
    Floor pans are repair. The rust was not horrible so I just used some galv 18 gauge I had left over from some other projects. After I figure out the new hole in the floor for the dual master cylinder, I will peal and seal the floor and install the mat Newfisher sent me........
    The headliner was shot and removed last summer. The left over insulation and glue has been now removed after a messy hour ordeal with a wire wheel on a 4-1/2" grinder. Now ready to install peal and seal and eventually figure out something for a headliner.
    My residual pressure valves showed up yesterday......so I may start on the brakes this weekend. Maybe........
  9. Coach529
    Coach529 Member
    Jamestown, ND
    Little or nothing in the form of forward progress this past weekend.
    RH front shock is mounted but I did not get around to the LH side.
    I drove all over town and got stuff from all three auto parts stores to get my all my brake stuff lined up.
    Thinks I have all the fittings I need to get it done....hopefully!!
    Today I was working on some other projects, so Henry go pulled out into the driveway. 8 hours later....we had 8+ inches of snow. yuck!!
  10. Coach529
    Coach529 Member
    Jamestown, ND
    No forward progress lately.
    I am giving myself a deadline of a couple weeks to get this baby on the road!! Need some motivation!!
  11. JW 54
    JW 54 Member
    Cypress Texas
    The nice weather up there should help.:)
  12. Coach529
    Coach529 Member
    Jamestown, ND
    Finally this week we have had some nice weather. 60s and 70's and dry.
  13. Makin' Memories
    Makin' Memories Member
    Minnesota
    I really like tracking your progress and the photo updates that you do!
  14. Coach529
    Coach529 Member
    Jamestown, ND
    Thank you!!
  15. Coach529
    Coach529 Member
    Jamestown, ND
    A little headway last night.
    Master Cylinder bench bled. Truck jacked up and on jack stands.
    Master cylinder installed and I double flared a couple small sections of brake line!!
  16. Coach529
    Coach529 Member
    Jamestown, ND
    Plugging along!!
    Brake light, tail light and blinker wiring ran to back of truck.
    Front end completely greased and cotter keyed.
    Brake lines ran. Started the bleeding process and am having a heck of a time with the prop valve tripping. I am just going to order the tool to keep it centered and some speed bleeders to ease the process
  17. Coach529
    Coach529 Member
    Jamestown, ND
    Last nights progress.
    Drivers side front shock is mounted.
    Peal and sealed the roof in the cab.
    Got a good game plan for building my rear shackle mounts which I hope to work on today after work!!
  18. Coach529
    Coach529 Member
    Jamestown, ND
  19. Elky67
    Elky67 Member
    Bavaria South
    Great pics, like always! I?m also thinking about the installation of these latches,
    as i have to slam shut the drivers door pretty bad:(
    What about your doors, do they close with ease, or do you have to slam them also, just curious?
    I?m really looking forward to the final result of your ride.
  20. Coach529
    Coach529 Member
    Jamestown, ND
    My drivers side latch is shot, and the passenger side took a heck of a slam to latch solidly.
