Original Firewall hole pattern
Discussion in '1947-1954' started by cmkruse, Jan 15, 2014.
  1. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Them Holes
    Rustydog, Okay on the mat clip hole. I didn't know they were that high up but it figures. I should be good to go now.
    LaTroca52, Why?
    Nate, Was that a stock installation location for a dealer installed turn signal system or just a weird idea?
    Me I can't wait to count my holes!!! Come on Spring!!!!:D
  2. RustyDog
    RustyDog Member
    Lakeland, Fl
    Please enlighten me oh wise one. Where? That thing below and to the right of the heater valve? There is a matching one on the other side. Nothing was there when I got it, so I have no idea. This thing has more holes that appear to be for marker lights than I would ever imagine needing. Both the bumper fill panels have extra holes that look like they would be for a couple of small single mount lights, and the rear sides have 2 holes directly vertical and about a foot apart? I am planning on putting a brake and signal light in those spots, but I can't seem to find any pictures of one with something similar.
    Sorry these are the best photos I have. Can't make out the holes on the front fill panel, but the back has 3 on both ends and I think the rest all match up with the mounting brackets.
    T.S. Flasher Bracket
    yes , that one below the heater valve :p .
    I wonder what they're were doing with it , I've NEVER seem one under the hood that I can remember , GM surely didn't approve :rolleyes: .
    Nice picture of the panel ! .
  4. RustyDog
    RustyDog Member
    Lakeland, Fl
    I'm definitely not anything close to an expert on these things. The 2 mounts appear to be stock as the holes are perfectly lined up and evenly spaced. They were also mounted facing the same way. Maybe it was a mount for some accessory item?
    Again, not an expert, just a guess.
  5. Guest5979
    Guest5979 Guest
    why?
    Cut down on engine heat smooth and pretty firewall redirect the wire harness and a smoothe and pretty firewall
  6. RustyDog
    RustyDog Member
    Lakeland, Fl
    Nate,
    Someone suggested they were used to hold the metal part on the wiring of the under hood light and that this one had 2 lights. I am clueless.
      File size:
      38 KB
      299
      File size:
      99 KB
      289
  7. spurgeon
    spurgeon Member
    Hose clip, same as on the inner fender liner? Where are they located for the heater without the valve?
    Nope
    On both counts ~
    Look in the factory accessory catalog to see how those items were installed .
  9. RustyDog
    RustyDog Member
    Lakeland, Fl
    What? Now you expect us to read instructions?
    Pictures , Mon ! pictures :p .
  11. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Isn't that where the horn relay goes?
    :D
    (Runs for cover.)
  12. DeadZoneTruckin
    DeadZoneTruckin Member
    Horn relay ?:D
  13. RustyDog
    RustyDog Member
    Lakeland, Fl
    It had a single horn mounted under the radiator splash apron. Didn't use anything that resembled these brackets. Might be possible it had 2 mounted on the firewall at some point?
  14. Haasman
    Haasman Member
    N. CA, south of SF
  15. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    AWESOME Super Thanks to HASSMAN
    Hassman, THANKS for the attachment. I see it's for a 53 and I have a 49 so I know there are minor differences but this should answer the majority of the hole "whole" issue. :D
