Original Firewall hole pattern
Them Holes
Rustydog, Okay on the mat clip hole. I didn't know they were that high up but it figures. I should be good to go now.
LaTroca52, Why?
Nate, Was that a stock installation location for a dealer installed turn signal system or just a weird idea?
Me I can't wait to count my holes!!! Come on Spring!!!!:D
Rusty Dog ;
I'm still trying to figure out why they put a turn signal flasher bracket in the engine compartment ?! :confused: .
Please enlighten me oh wise one. Where? That thing below and to the right of the heater valve? There is a matching one on the other side. Nothing was there when I got it, so I have no idea. This thing has more holes that appear to be for marker lights than I would ever imagine needing. Both the bumper fill panels have extra holes that look like they would be for a couple of small single mount lights, and the rear sides have 2 holes directly vertical and about a foot apart? I am planning on putting a brake and signal light in those spots, but I can't seem to find any pictures of one with something similar.
Sorry these are the best photos I have. Can't make out the holes on the front fill panel, but the back has 3 on both ends and I think the rest all match up with the mounting brackets.
T.S. Flasher Bracket
yes , that one below the heater valve :p .
I wonder what they're were doing with it , I've NEVER seem one under the hood that I can remember , GM surely didn't approve :rolleyes: .
Nice picture of the panel ! .
I'm definitely not anything close to an expert on these things. The 2 mounts appear to be stock as the holes are perfectly lined up and evenly spaced. They were also mounted facing the same way. Maybe it was a mount for some accessory item?
Again, not an expert, just a guess.
why?
LaTroca52, Why?
Cut down on engine heat smooth and pretty firewall redirect the wire harness and a smoothe and pretty firewall
Nate,
Someone suggested they were used to hold the metal part on the wiring of the under hood light and that this one had 2 lights. I am clueless.
Rusty Dog ;
Hose clip, same as on the inner fender liner? Where are they located for the heater without the valve?
Nope
On both counts ~
Look in the factory accessory catalog to see how those items were installed .
It had a single horn mounted under the radiator splash apron. Didn't use anything that resembled these brackets. Might be possible it had 2 mounted on the firewall at some point?
AWESOME Super Thanks to HASSMAN
Hassman, THANKS for the attachment. I see it's for a 53 and I have a 49 so I know there are minor differences but this should answer the majority of the hole "whole" issue. :D
