1947-1953 Chevy truck Parts
Discussion in 'Truck Parts for Sale' started by f4fantm2, Jul 7, 2009.
  1. f4fantm2
    f4fantm2 Member
    Kentucky
    I have a lot of parts that I took off a '50 Chevy pickup truck I rebuilt simply because I wasn't enough of a body man to re-work them, so I bought repo parts. Included are:
    2 bedsides, bed front, and tailgate, all in useable, reasonably good shape
    Set of runningboards, small rust hole in each one above rear mount
    Primer painted grille, few small dents, otherwise great shape, w/lights
    2 doors, surface rust only except at the bottoms (will need patch panels)
    Miscellaneous door/window hardware
    Some stainless door trim
    Heater
    Set of 4--16" 6 lug wheels with 6.00-16 tires mounted (90% tread left)
    216 engine (running when I took it out to replace with 235)
    3 speed transmission, worked fine (replaced with T-5)
    2 fiberglass fenders (bought new before new metal front fenders were available, decided to go with metal for my truck when they were)
    Enclosed drive shaft and rear axle
    Stainless glove box door
    Radio blanking plate (to fill hole in dash if no radio)
    Most of the front axle/suspension
    You can view pictures of these parts by clicking on the following link:
    http://photobucket.com/fantm2
    If you see something you are interested in, let me know and we can get together on a price. The big parts will be pick-up only. If anyone wants all of it, make me a reasonable offer and it's all yours.
  2. Guest5979
    Guest5979 Guest
    parts
    Hey bob i sent you a private message about some parts.
    Robert
  3. Chiro
    Chiro Member
    Hi Bob,
    Sent you a pm also.
    Andy
  4. JUNKHOARDER
    JUNKHOARDER Member
    Middle of nowhere N.J.
    Radio delete plate
    Looking for the radio delete plate plugs that attatch plate to dash .
  5. jfjbjr
    jfjbjr Member
    USA
    I have a pair of original hardware to hold your '47 - '53 radio delete plate to the dash.
  6. lodwn50
    lodwn50 Member
    Tn
    do you have a delete plate?
  7. willieb6
    willieb6 Member
    Need the speedometer gear out of the trans. thanks willieb6 rsbailey@att.net
  8. fyritup52
    fyritup52 Member
    I'm interested in the tailgate.........thanks
  9. sleepindawg
    sleepindawg Member
    Topeka, Ks
    I as well sent you a pm Bob..........
  10. 51 chevy pu
    51 chevy pu Member
    Lansdale, PA
    need the 3 speed trans
  11. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    I sent you a PM
  12. Mtneermike
    Mtneermike Member
    Smyrna TN
    16" wheels
    What is the price for the 16" wheels and will you ship?
  13. dan cocomise
    dan cocomise Member
    tires rims
    are those bias tires ?how much for set of 4?
  14. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    I'm interested in your 3 sp transmission. Is it still available?
    Thanks, Tony
