1952 Chevy 3600 - Project for me and my boy...
Discussion in '1947-1954' started by 2OR4Wheels, Jun 21, 2013.
  1. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yeaa. dad didnt bring his torch with him to AZ so it was a lot of work. PB blaster is my freind and was used... i took 3 leafs out of the pack on all 4 corners. no pictures because you cant really tell its lower with just the cab. no bed or front end is on the truck. the cam comes in on monday
    luckly dad has a 80 gal compressor so its easy. i didnt put the 1/2 ton axle in yet. ill run the 3/4 ton till i get her runnin swell then swap it out if i want to go the speedway route with a drop axle. yea ive been spendin a lot of time in ace hardware buyin new boltz for the sheet metal. i took someones advise and bought a tap and die set. i clean the thread and makes for putin bolts back in super easy. harbor freight is a good place
    Rusty Nuts
    The advice of a good penetrant and allowing it to work is spot on ~
    As is whatcking it afew times to shock the rust and help the penetrant to wick in ~ when they suggest tightening the fastener after you've soaked it , only 1/16 th a turn will do ~ as soon as you feel it turn , spray more penetrant and work it bck and forth , back and forth , with each movement it'll get looser and looser...
    Is no one reading my 292 engine thread on the '67 ~'72 pages ? .
  3. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    As soon as I have time to put a 220 outlet in, I am gonna pick up a new compressor. Hopefully that will be sooooon...
    I don't care for Ace, they are way too over priced, although, they have a much better selection of hardware than most places in town. Tap and die set is a must, I have 2 or 3 so I will be using those as well.
    I love Harbor Freight for some things, but have having to drive to Tucson to go. I normally load up once or twice a year when I do though. Wish SV would get one here, I think it would do pretty well!
  4. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Can say that I have ventured out of the 47-54 threads... :confused:
  5. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    only thing i buy fron ace is their nuts and bolts and their brand spray paint because it has the fan spray, which sprays larger areas better
    we're gettin a tractor supply on fry blv past target...
  6. DeadZoneTruckin
    DeadZoneTruckin Member
    A friend of mine checked into buying into a H.F. franchise
    { & S.V. was one of the locations he was shooting for }.
    Now all he has to do is come up with the $1,000,000 H.F. wants to give him a store.
  7. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Well damn, that's all?! Tell him I'll write him a check in the morning! Lol :D
  8. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    we need one in SV or in whetstone. thats why they ask for you zip code, to see where you are from
  9. vwnate1
    Topic Drift
    Well ;
    I didn't think it appropriate to post here about my newer old truck works....
    Hop on over and let me know what you think .
  10. vwnate1
    Spray Paint & Hwe.
    Their house brand of Foo-Foo paint for engine re sprays ? . I need some GMC Red for my 292 I6 engine .
  11. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    no, reread my post
  12. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Garage time
    Got a few hours of garage time, in which i could work on what I wanted to work on. Cleaning/organizing the garage may make my work easier, but that will have to wait for a little while. :D I was able to get the grille off, the front fenders, inner fenders, radiator, and most of the wiring pulled back. Will pull the motor tonight, maybe the transmission by the end of the weekend. Then I will be working on cleaning the frame so I can paint the front half, and bolt on the drop axle that Sid sent a few weeks back. Progress!
  13. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Pulling motor/trans.
    So my progress didnt go exactly how I had planned. After searching the 'ol interwebz, I had read many posts on different forums that suggested it is easier to pull the motor/bell housing/trans. as a unit. And that is what the service manual suggested too. Well......... After trying to finagle it out, and banging my head, I realized there was just no way it was coming out without jacking the cab up. So I starting searching forums again...
    Note to all that are pulling a 235 with a manual 4 speed (SM420): Remove the transmission first. It wont clear the crossmember and the bottom of the cab. Read on one post that it is 12", and the clearance is only 10". I'm sure some of you guys that have been around for awhile may already know this. Lesson learned.
  14. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yours is lookin a lot like mine. wednesday ill try a 2nd oil pan gasket to see if i can get it right for a 3rd time. then hopefully i can pull it out of the garage and start puttin the front end back together
  15. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Was it because of a shotty pan gasket that it was leaking? Would hate to have to pull the motor again after install (or re-do anything for that matter).
  16. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    YUUUUUP... i got a game plan now. mout mount is out of the way and im gonna rgb (or whatever the rubber gasket shit is called) the gasket on, on the ends, let dry and then install it.
  17. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Motor/transmission are out. Since I was doing this by myself, I had a bit of an issue with the transmission. I had put a jack under it, removed the 4 mounting bolts, and started to separate it from the bellhousing. It wanted to roll, probably rolling off of the jack if I had pulled it all the way out.
    So I had remembered seeing some contraption that a guy built that was 2x4's with a boat winch on it to lift the transmission from the access hole in the cab, then lower it to the ground. Remembering this gave me the idea of using the 2x4, drilling holes, and bolting to the top of the transmission to keep it from rolling. After I pulled the trans. back far enough to clear the shaft, I unbolted the 2x4 and lowered the jack to the ground. Worked well since I didnt have anyone around to help me.
  18. ccharr
    Thanks for sharing that with us I'll have to remember that one.
  19. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    give me a call chad! i have 4 days a week off. ill give you a hand! i just scored a chevy bench seat of my uncle today
  20. Zig
    Necessity is the mother of invention, right? Cool idea for those of us that like to do it on our own and not ask for help. ;)
