We have a 1953 chevrolet first series (small rear window) truck that had a broken driveshaft. We got a new front spline welded onto the old shaft at a driveline service. The front of the differential housing near the rivets that fasten the torque tube to the diff has the 3 bolts with locknuts that anchor the inner race of the pinion shaft bearing(?) I believe that these only serve to keep the race from spinning(?) Trouble is, now that Dad has reassembled the shaft into the torque tube, when he tries to anchor down the 3 bolts they do not strike anything. Also, the driveline service sent back a long front bushing, when the original ones that it had were the two smaller ones. The front bushing right behind the front splines got thrashed when the shaft sheared, and I had to cut and re-weld the front of the torque tube to get the bent spline section out. Question is, is it critical to tighten down the 3 bolts? He mostly drives around his farm at 5 MPH. Are the 3 bolts only in '53s and not in '55? Could driveline shop have put a later pinion shaft bearing in that has no recessed groove for bolts? ALL INFO APPRECIATED as dad is truckless!
