1954 3100 engine question
Discussion in '1947-1954' started by roberji, Aug 2, 2023.
What is the cannister-type part on the right side of the engine block, about 5 1/2 " high and 2"n
Poll closed Aug 9, 2023.
  1. Filter
    0 vote(s)
    0.0%
  2. Vent
    0 vote(s)
    0.0%
  1. roberji
    roberji Member
    I need help identifying . the cannister-looking item between the distributor and fuel pump. Its a 1954 3100 with a 235. The cannister is 5 1/2 " high and 2" in diameter.
  2. Bill Hanlon
    Morris Ranch TX
    A picture would help. Too small for an oil filter. Most likely you are asking about the draft tube. One end pushes onto the block, the other end is an open tube about 1" in diameter with the end cut off at an angle. The angle end hangs down into the airstream at about the level of the bottom of the frame. The purpose is to allow crankcase fumes to vent to the outside world.
    vwnate1 likes this.
  3. Bill Hanlon
    Morris Ranch TX
    Does it look a lot like this?
    This one is from my GMC 302, but a Chevy engine that had an oil filler cap on the valve cover would have a draft tube that looks a lot
    like this one.
    vwnate1 likes this.
