1970 Chev C10 350 Carb
The smallest would be a two barrel.
Smallest 4 barrel? I would say a 650cfm would be as small as I would go.
DV
i agree with dv that that smallest carb would be a 2 barrel. but i for a four barrel you could go as low as a 500 cfm from edelbrock or other carb manufactures, but i would go with a 600cfm is the lowest i would go.
cowboy
1961 chevy 1/2 ton shortstep known as sarah (496 big block coming sooner or later)
:) howziit guys!
using the calculator at www.smokemup.com
at 85% volumetric efficiency and 70*F, a sbc 355 would need 392cfm to sustain 4500rpm.
480cfm at 5500rpm, and
600cfm at 6875rpm.
FWIW, a big block 454 needs 502cfm at 4500rpm, and
600cfm at 5375rpm.
BTW, THE PINK LADY had a 750cfm #####.
for gas mileage testing, i replaced the carb with a 600cfm Edelbrock...jetted TWO STEPS LEAN, in power and cruise mode.
still testing; low-end response is EXCELLENT, but i can FEEL the midrange/high-end power loss.
the spark-plugs read brown...and Noooo, this 454 engine hasn't burned out yet.
water temp range is 185*-200*F, runs on 87Octane, no pings, no dieseling...but it is a LAZY RAT ENGINE.}> }> }>
