53 chevy 1/2 ton transmission
Jim G
Apr 23, 2012
23
I keep finding more challenges. In process of trying to fix the U joint on my 53 Chevy 1/2 ton I found that the all in one casing (U joint attached to transmission cover) has a crack and I may need to get a new casing. Or can it be welded. If not, any suggestions on where to find/buy a not too expensive casing. Ay yi yi!
Jim G:rolleyes:
Is it the transmission casing or the bell that is cracked. I have both. A real good welder can weld it as long as the now how to weld cast
Univ joint/tranny
thanks for your on-going help. what do you mean the "bell"? It appears the "cover" is all one unit.
thanks.
Jim G
chevy 1/2 ton
Gary1o2: just so you know I sent you a private message.
Jim G
