Any interest?
Discussion in '1947-1954' started by Depoebay, Jun 29, 2017.
  1. Depoebay
    Depoebay Member
    Ongoing progress is being made.
    First thing done was to cut the sheet to length. Then ripped the piece in half.
    The bed is 50 inches wide. Sheet of plywood is 48 inches wide less kerf of the ripped cut. Decided to sister on a 3/4 inch piece on the outboard sides. This will be hidden by the bed angles.
    sorry for the sideways pics. Pony clamps, tight bond glue and 18 gauge nail gun was used. Care was taken not to shoot nails into location were the bed bolts go thru the bed cross braces.
    Next careful measurements were made for the bolt heads on the cross braces. Using a 1 inch Forstner bit I drilled pockets for the bolt heads. Aftermarket stuff.... rrrrggghhh 3 inch lowering springs create a problem with the frame . Used a router to create a pocket for the frame arch. 20170723_125337.jpg
    Pic shows bottom side with pockets. 1 coat of sealing primer then two coats of oil based enamel. Also had to use a router to create a cut out for the front.
    Depending on how many bed runners you are going to use... Mark and drill the holes for the cross braces.
  2. Depoebay
    Depoebay Member
    Well the bed is done. . 4 coats of West Systems epoxy. I 20170817_113417.jpg 20170905_165200.jpg ended up with a 5/8 to 1/2 inch gap in the center. here are some pis 20170817_113417.jpg
  3. Depoebay
    Depoebay Member
    Sorry for the delay I ended up with about a 1/2 inch gap in t 20170817_113417.jpg 20170905_165200.jpg he center. Biggest problem was over the relocated gas tank. could not get at the nuts. Ended up using stainless Molly's. 4 coats of West Systems epoxy. Here some pics
  4. Bill Hanlon
    Morris Ranch TX
    Looks great, but will it pass the Chevy vs. aluminum Ford "drop a heavy tool box corner down in the bed" test? ;)
  5. wolffcub
    wolffcub Member
  6. Depoebay
    Depoebay Member
    Wolfcub ...I like it .. nice job
