Jr_
Timing Issue,
Turns out there was no timing issue. I thought there might be a problem because it was so hard to start. I have set the valves and timed to the BB for now. Also adjusted the carb to highest steady vacum at 800 rpm.
Now I am working on the carb (Carter). Seems like there is some play in the connection to the accelerator rod that does not let it go full closed. I can jingle the accelerator and it will idle down to 550 real smooth. Looks like the problem is the accelerator rod connector on the carb is loose where it goes into the carb body. Have not had time to study in depth yet. If I get this figured out I am hoping to get my mileage up from 9mpg.
