Road Draft Tube
Remember , it is full of baffles and often is all plugged up with sludge & goo , how to clean it ? Simple :
Take that old BBQ and stoke the hell out of it ,as it turns red lay the road draft tube on the grill and close it up ~ after an hour or less, the heat will cause the built up sludge to burn away , be aware it'll stink like the dickens so make sure SWMBO is off visiting her sister or what not .
Once it's all done and crispy , let it cool and tap it on cement sharply until the ashes stop falling out , wire brush and re-paint , should be glossy black .
DO NOT BEAD BLAST IT !!! the beads will stick up inside it then over time they'll drop back ito your oil and grind the crankshaft etc. to junk....
