Different transmission fit on a engineblock?
Discussion in '1947-1954' started by wokri, Nov 15, 2014.
  1. wokri
    wokri Member
    Germany
    Hello,
    I have one question, does a four speed transmission fit on every 235 cui engineblock or need I a special engineblock for these transmission?
    I ask this, cause someone sells in Germany a complete engine. I will buy it, cause my engineblock have a crack which water is leaking.
    Wolfgang
    Wokri ;
    If it has a 216/235 no and yes .
    Take a close look see before buying some one's junk .
    I bought a long stroke i^ engine for $100 and glad I only paid that for it was if needs new cylinder sleeves , I saved the head but will prolly junk the block as no one seems to want it for free .
    Caveat Emptor ! .
  3. wokri
    wokri Member
    Germany
    Hello Nate, here some photos from the seller of the engine. I sure that I have to overhault the block, so that I can use many of the parts of my block.
      File size:
      75.7 KB
      283
  4. Chiro
    Chiro Member
    235?
    That does not look like a 235 to me.
    Anybody else?
  5. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Looks like it might be a 216.
  6. vwnate1
    Mystery Engine
    It might be a splash lubrication 235.....
    I'd like to see the other side of it and the casting & stamped in numbers .
    I understand these are hard to find in Europe but be very clear what it is and what you want before paying more than scrap price for it .
  7. wokri
    wokri Member
    Germany
    Okay, thank you guys.
    I think, I didn't buy it and will look after another one.
  8. vwnate1
    Before You Bail
    Let us know what you have and what you want.....
  9. gary1of2
    gary1of2 Member
    Valley Springs, CA
    I agree with Larry it looks like a 216
  10. vwnate1
    Babbit Pounder Engines
    Came in both 216 and 235 versions....
  11. gary1of2
    gary1of2 Member
    Valley Springs, CA
    Vwnate, I thought that the lifter side cover went all the way around plugs it was 216. The lifter cover that was rectangle was 235.
  12. vwnate1
    216 & 235 Babbit Pounders
    BOTH sizes were available with this side plate (a crappy thing that leaks) in pre 1954 formats .
    This is why I said to CHECK before passing on this old engine core .
