jon0249
After reviewing several posts on the draft tube elimination process and replacing it with a PCV valve, I thought I'd give it a try. I'm now having an issue that I can't seem to fix.
The hose from the PCV runs directly to the vacuum port on the intake. After 5 minutes of driving, the engine starts spitting and choking and dies. After a few minutes, it will start up again, and will idle without any problems. But after 3-5 minutes under a load (driving), it repeats the choking and dying.
On one occasion, right after it died, I took the hose off the intake and noticed a small amount of white smoke coming out of the port. Figuring the blow-by was righ in oil, I figured I would disconnect it and the oil would eventually burn off, with a little help from a few shots of gumout. So I took the hose off and plugged the vacuum line.
After disconnecting, I'm still having the problem. I can't imagine that there was that much oil getting in? Also, not getting much white smoke from the exhaust, so this is stumping me. Anybody have any similar problems with this PCV replacement for the draft tube?
Thanks,
Jon
Thanks,
Jon
