omega7979
Hi People,
I have a question about the good ole 235.....I pulled the motor and trans today for a cleanup and paint job after getting it running like a top....my question is the 1/4 npt plug on the rear left side of the block(sometimes a petcock).
I removed the plug and did the usual stick the screwdriver in there and poke the sludge till the coolant started to come out but no coolant wanted to come out.
I stuck a #2 phillips screwdriver in there a good 4" and still nuthin...at this point I started to get curious about how much sludge is actually in the block and if its ok to leave in there.......I dont really feel like taking the whole engine apart to get the block baked and shot blasted.....cuz that will get into boring it out and all that crap.....basically too much money......It ran too good to touch.
I had a thought of taking an old throttle cable from a junk lawnmower and using the outer casing of it in a drill and kind of goin in that hole and use it like a drain snake till I got fluid to flow..... if ya know what I mean ??
I will be removing all the freeze plugs for replacement .....so maybe once I get em all out i'll have a better idea of what to do maybe??
I'm just afraid if i dont get it all cleaned out i will have a problem with overheating in the future.
Thanks again,
Leon
Thanks again,
Leon
