Engine identification
Discussion in 'Performance, Engine, and Transmission' started by etexghostrider, Jul 11, 2014.
  1. etexghostrider
    etexghostrider Member
    East Texas
    New to AD trucks and the forum and could use some help. Have recently purchased a '49 five window 3100 which has had the engine changed. Was told it was a 235 replacing a 216. Just trying to identify the current engine.
    Block casting # 3769716 , the head # is 3836848, the stamping on the flat by the distributor is FC 409J. The valve cover is held on by two nuts.
    Any information will be appreciated.:)
  2. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Correct Head
    The head number is correct for a 235 but I can't find anything else for you sorry.:(
  3. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Numbers
    I also found the block casting number from some listings at the old car manual project. Block 3769716 is listed as a 60-61 and the Head; 3836848 is used on 53-55 corvette 235 and another listing shows 53-62 passenger and all corvette.
    The engine code I can partially identify the F is for Plant (Flint) and the end "J" is an application code which is for a standard 235 Thriftmaster. If the C is really an "O" or "0" then that is a date code 04 (month= April) and 09 is (day=9th).
    The valve cover has probably been changed or they used the original 216 valve cover and used a valve cover adapter kit which is two studs to replace bolts in the rocker arm shaft and the nuts for the hold down on top.
    Hope this helps.
