RE: U-joint Service
Gordon ;
You needn't move the rear end back to acess / service the u - joint but it _does_ help , no need to split the brake lines nor parking brake cables either .
Loosen the collar on the back of the U - joint bell cover then remove the 4 bolts and slide the bell cover back as you twist it , if lots of old grease on the Torque Tube , you'll have to clean it for it to slide back .
Often the tiny bolts holding the U -joint to the trans. out put yoke have worked loose , allowing the joint Ay. to wobble & vibrate as you drive , if this is the case , replace the bolts being _sure_ to use grade 12 bolts as soft bolts _will_ break .
New U - joints are available , usually made in Argentine with so-so quality so do some test fitting before you button it up .
You'll need a gasket kit , IIRC Fel-Pro is the company still making it . use the orginal leather seals unless they're compelety ruined .
The paper gaskets should be used to shim the bell so it's possible to move it by hand , not droop of it's own weight but not stiff either . hand sand / polish and dents or deep ridges out so it moves smoothly before shimming it .
The U -joint bell is supposed to be full of tranny oil (90W gear oil) and you can remove the fitting on the very top of the bell to fill it , it may be a Zerk fitting as that's what the factory used to rapidly fill it when it was built but never , _EVER_ put any grease in there .
The oil level in the tranny is important , as you fill it , the oil slowly seeps through the rear output bearing
s cage and fills the bell area so go slow and always fill the tranny right up the the lower edge of the filler hole .
Adding a 1/2" NPT magnetic drain plug to your tranny is the smart thing to do .
I hope this helps....
