Engine pulleys & numbers
Discussion in '1967-1972' started by mikiesride, Apr 5, 2020.
  1. mikiesride
    mikiesride Member
    So Cal lower desert
    Hello all, I have a 68 Chevy C10 1989 305ci, 1992 4l60 trans. When I bought the truck the engine was all setup for a long w/p and Alternator on pass side no a/c at the moment but I will be adding it later on (just not yet). I have already moved the Alternator to the drivers side and am going with a short w/p along with power steering mounting under the Alternator.
    What I am looking for is all OEM original pulleys. I do have the Alternator bracket mounted to the Head and the power steering brackets mounted to the lower face of the motor and the drivers side motor mount front bolt which I believe all that is correct for an original looking under the hood setup minus the pulleys.
    Does any body have the correct pulleys stamped numbers (or where to find them or links) handy for a short w/p and power steering with future a/c. I will NOT BE USING a fan clutch setup just the blade type fan. I have some pulleys only be the seller of them telling me they are correct for a short w/p setup.
    Any help would be very much Appreciative.
    thanks, Marvin
