Bill Hanlon
SOLD, but I can't delete the listing.
For sale: A set of Fenton Chevy 216/235 dual exhaust headers, marked "CHEV" "H604" FRONT" and "H603-REAR". They were mounted on a GMC 302 head and have had a little grinding done to the surfaces that the "hold downs" that mount on the studs contact. One of the nuts was a real PITA to get off of the GMC because of close clearance, which I think could be solved with judicious use of a Dremmel tool.
The Chevy Fenton manifolds need a bit of port "blending" when used on a GMC head that had not been done when I got the manifold. I did that and then shot the manifolds with some gray VHT paint. The port blending should not preclude their use on a Chevy 216/235 if you'd rather use them there.
I'll include the hold-down hardware that has been tweaked to fit with a GMC intake manifold.
$125 if you pick up 30 miles north of Houston Tx. They will fit in a USPS flat rate box for $18.85 + insurance.
