Hey guys, I would like to pop in here for a little help also. I am not installing dual exhaust (yet) but am trying to get my 235 running right with dual carbs on an offenhauser manifold.
It runs great with either of my carbs installed with the stock manifold. I have adjusted the valves and timing is dead on. Anyway, with the dual setup installed, it's not running very well at all. I'm sure it's too rich. Pulled a plug and observed some soot plus a little bit of black smoke out of the tailpipe. I do have a "Uni-syn" and appear to have the carbs in sync.
So my question would be this: when throwing on an additional carb do you need to "down jet" the carbs? Each carb has a 55 jet in right now. Another question is what about the vacuum advance hose for the distributor? Do you just run it off one of the carbs or do you need to tee off of each carb?
Thanks, Willie
