Front Drop Coil Springs: 2" or 3" - '65 C10
Porterhouse,
Could you measure and then post the drop you have now, and also give us an update when you get the new 3" drop springs?
That would be a big help. Measure from the top of the wheel opening to the front axle c/l, like this:
Thanks in advance!
FWIW: I used 4" Heavy Duty Drop springs on my truck. The standard drop springs, be they 3", 4" or 5" are wimpy compared to stock. Heres's more on that, go to post 266: https://talk.classicparts.com/showthread.php?t=13928&page=18
John
Currently I have 16" on the drivers side and 16-3/8" on the passenger side. The difference in height was explained by the springs not seating in the pockets.
New springs arrived, coils are much larger in diameter so they should ride nice. Don't know how soon and I will get them installed.
Thanks for posting Porterhouse!
So to sum this up...
I just finished installing CPP 2" front springs .... on my 63 longbed.
I decided that if I'm going to pay for the alignment the ride height should be what I want so I cut my front coils, about 2/3 of a coil. This dropped the front about another 1-1/2"
Currently I have 16" on the drivers side.....
So if we take the 16" dim and add 1-1/2" we get 17-1/2" for a 2" drop spring.
Mine is 17 inches on both sides. Back in 1997 I installed 1 inch lowering springs in front,]
And Mark has 17" with a 1" drop spring.
I think what we are finding here is different drop rates based on different springs. Caveat Emptor?
I'd still like to know what you end up with Porterhouse, once you get the 3 inch drop springs in.
to be continued............................................................................................................
So I finally got the alignment wrapped up, with CPP's 3" drop springs the final measurement was 15" from center of hub to bottom of fender riding on P235/75R15 tires on 15x8 rims with 4" BS. Im happy with the stance and the ride.
Thanks. It rides nicer overall, less mushy, except for the big potholes, really jars the spine. I will play with the rear overload springs, right now its riding on the leaves, i could drop the rear another inch or so by swapping the mounts, that might help.
When I first got my truck it had those overload springs, and they were about a 1/4" from touching. When the truck rear axle would see a bump it would launch your butt off the seat like a carnival ride. :eek:
Overload springs looked like these (not photo of my truck)
But on my truck they welded I-Beams cut in half as brackets :( (photo of my truck)
Gone...
I did keep the brackets though at the trailing arms. Drilled a hole in it for a shackle, thought it would be a good tie down point in case I ever had to trailer the truck.
I assumed they were all the same. Mine hit the top of the axle. There WAS about 2" between the pad and the axle. When i lowered the rear that 2" clearance went away. Ill try flipping the mount on the frame and see how much clearance i get
Topic Drift : Over Load Springs
Thanx fellas ;
Did / do they make something like this for my '69 C/10 with rear coil springs ? .
I work it lightly but I always like having overloads as Chevy Light Duty Trucks are rather lightly sprung from new .
TIA ,
